Have you scanned it to make sure its the cam sensor? Just curious, dont need to spend money if you dont have to.
yeah, but i cleared the codes after replacing it and the code is back. im pretty sure its a timing issue, the car is in a permanent limp mode and is stalling when coming to a stop and will not build any boost. im pretty sre i fucked something up when i manually rotated the crank for valve cleaning.
Saturday,17,August,2013,12:13:38:33552
VCDS Version: Release 11.11.6 (x64)
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Control Module Part Number: 1K0 907 115 B HW: 1K0 907 115 B
Component and/or Version: 2.0l R4/4V TFSI 0030
Software Coding: 0403010A1C070160
Work Shop Code: WSC 00191 264 15243
VCID: 256F28B7EC62163073D
2 Faults Found:
000400 - Fuel Pressure Sensor (G247)
P0190 - 001 - Circuit Malfunction
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 148139 km
Time Indication: 0
Date: 2000.00.00
Time: 00:17:55
Freeze Frame:
RPM: 822 /min
Load: 59.2 %
Speed: 0.0 km/h
Temperature: 66.0°C
Temperature: 33.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.224 V
000835 - Camshaft Position Sensor (G40)
P0343 - 001 - Signal too High
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 148139 km
Time Indication: 0
Date: 2000.00.00
Time: 00:17:55
Freeze Frame:
RPM: 1597 /min
Load: 22.0 %
Speed: 0.0 km/h
Temperature: 66.0°C
Temperature: 32.0°C
Voltage: 14.224 V
Readiness: 0110 0101
