APR tuned GTI needs new sparks
LoyalSage
California
MKIV & MKV R32
Guys,
I have a stage 2+ 2008 MKV GTI (FSI) coming up on 60k miles, I am going to replace the spark plugs but do not know to use stock or after market.
I have read around that most tuners tune the cars using stock plugs, so I assume using any plugs other than stock would not be a good idea?
I have an APR Downpipe, APR modified High Pressure Fuel Pump and a Stage 2+ flash.
Ideally APR can answer this question on their recommendations.
Thanks!
604GTI
#yoloSWAG
Vancouver
Im using the NGK one step colder plugs on my car with good results and my car has similar mods
LOUCFUR
DIÄBLÖ
Las Vegas
GTI MKV
is there any benefits with aftermarket ones?
carbuyer
mobile
why pay the extra cost for iridiums?
just get cheaper coppers, your choice of either stock heat range or one step colder (id go colder since you are in cali/your mods) and change em out semi-often.
spark plugs are easy to change on our cars
Ditto. The code is BKR7EIX. Use with gap as set out of the box.
604GTI
#yoloSWAG
Vancouver
My car did feel better it seemed with these in, but that could be because my stock plugs were fouled. Definetly buying these again .
LoyalSage
California
MKIV & MKV R32
excuse my ignorance on this topic, but what will be the result of going one step colder than stock?
you mentioned you had in mind my location and mods, i would like to understand how it all comes together.
thanks!
NJdubber
Performance Enthusiast
Northern NJ
Audi A3 2.0T FSI
Anyone got the part # for stock heat range copper plugs from NGK?
604GTI
#yoloSWAG
Vancouver
No reason to deviate from the stock plugs. What do you think, Stage 2 makes it a race car? LOL.
Dont know if that was directed to me but it makes my car run smoother, thats why.
Cryptic1911
CT
2008.5 GTI
When you increase the boost, it creates more heat in the combustion chamber. Different heat range plugs help to regulate the cylinder temps to help fight pre-ignition. There's many people on here that bitch about timing pull, so trying different plugs may help with their issue.. maybe next time do a little research before making smartass comments. :paddle:
fastgti69
M3 Eater
SoCal 818
i would agree if he had a BT. stock plugs are good enough.
