spring rates? neuspeed sport v. H&R sport
sabba
NEWB
nassau county
which is the stiffer of the two - or I one knows of a stiffer spring not mentioned feel free to post. Can really find what I am looking for. On my current s/u I am rubbing with the H&R springs and was wondering if running a stiffer spring would prevent my rears for rubbing. The fender well is a little different in the A3 compared to GTI -- in real world this relates to A3 having to run a more conservative wheel offset.
current s/u: billstein sports - 225/40/18 potenza re-11s - 18"x8" et 45 wheels
Thanks
MkV_2.5
Quebec
they have pretty much the same spring rate... but for some reasons, the H&R Sports ride wayyyyyyy harsher than the Neuspeeds
MkV_2.5
Quebec
I'm running H&R sports and 19x8.5 ET48 wheels... I do not rub a bit, do not scrape my front lip either... didn't even need to do that fender liner bolt removal thing
TheJakofallTrads
Car-less
Bronxville, NY
Audi RS3
Neuspeeds are softer than H&Rs. the rates are 225lbs. front, and 350lbs. rear. H&R refuses to release their rates. I have Bilstein Sports and Neuspeed Sports on 18x8 45ET wheels with 225/40 Bridgestone RE-01Rs and never rub...I think your offset is too aggressive, the stiffer springs might help you though, no clue because I don't know the rate of the H&R's in the rear. Why not roll your rear fenders if you like the handling/ride though? It's cheaper than getting new springs and saves you another install.
From softest to firmest: Neuspeed Sport, Eibach Pro-Kit, H&R Sport.
rvan
San Diego
I called H&R and they released their spring rates to me. It was about 265 in lbs for the H&R vs about 225 in lbs for Neuspeed sports
mike2727
Hollywood, FL
more interested in the rear's....they didn't mention that to you by any chance.
Yes what is the rate in the rear ?
Mike
