boraboy
- Suffolk, UK
- Golf V GT TDI
My heating stopped working properly yesterday.
Its has dual climate.
with the climate set to either dual or single and the temp set high I only get good heat from the far left side vent. The left center vent is warm, the right center vent is cold and the far right side vent is very cold.
Being a UK car that means I have the cold vents on my side.
The fans work fine at all speeds and the water level is good.
The screen vent seems to be cold aswell.
I tried searching and found many no fans working or no heat at all but nothing about progressive heat from one side to the other.
I seen that there are some flaps or valves to under the dash which I beleive could be the problem but where are they and how easy are they to get to?
Any help or advice welcome, thanks
