nvr2low
- lake mary/winter springs, FL
I have a 2008 rabbit. It's nothing fancy as far as audio goes from factory. It had the iPod hook up in the air rest and the basic CD player.
Anyways , in the last year or so some of the speakers cut in and out and worked intermittent as they please. I figured it was blown speakers. So I replaced the front door speakers with a 3 way co axe speaker , eliminating the use of factory tweeters as well. I also spent a few days fighting the rear and doing the same with 3 way co axe speakers in the back. I have a two door so I know some of you feel the pain. I also installed a new head unit which is the 3rd one this car has had. After it was all said and done I tested them out. To my surprise at high volume it still does the same cutting in and out. I'm lost. To my knowledge this car didn't come with a factory amp or anything. I'm not an amateur when it comes to this as I've been doing installs and building mini trucks for years. So this one is alil over my head as far as wtf it could be. I didn't know if it was some kind of vw issue. Because the next step is to wire it to the head unit and throw and amp on it. But I'd still like to know what could be causing this.
Any help or insight would be great.
Thank you.
Thank you.
