Parts4Euro
Old 11-05-2008, 02:53 PM   #1
Colleton
Touring Car Champion
Colleton's Avatar
Drives: 2008 GTI w/DSG
CEL - P0234 "Overboost Condition"
I've gotten this cel twice now in the past week. Both times were when I was WOT, accelerating hard. The cel lit at ~80 mph both times.
Also, and I don't know if this is related or not, but the car went into limp mode for a bit yesterday.
What could be causing this?
I'm stage 1 APR if that matters. I've made an appt. To take the car in for service tomorrow, but am apprehensive that they will be able to see the requested and actual boost numbers and know I'm chipped. The car will be running the stock program with security lock-out activated when I take it in for service.
Any thoughts or advice would be greatly appreciated, thanks!
2008 GTI 2.0TFSI DSG: Votex Kit APR Stage 1 *SOLD*
2013 Focus ST: ST2 + Nav + Moonroof 252HP
2013 Shelby GT500: Supercharged Aluminum Block 5.8L 4V DOHC V8 662HP
Colleton is offline   Reply With Quote
Old 11-05-2008, 02:57 PM   #2
07Noside
Drives: 07BMP GTI 6MT/2010 DGM STI
The CEL IIRC does not record boost readings. The CEL only shows a record of velocity, engine speed and engine load. They will try to recreate the situation if nothing occurs while in stock mode they will most likely deem it fixed untill they can replicate and diagnose the problem. If you are only having this is issue in chipped mode you will not recieve any warranty work.
07Noside is offline   Reply With Quote
Old 11-05-2008, 04:04 PM   #3
Arin@APR
Arin@APR's Avatar
Drives: B8 S4 & MK5 GTI
Send a message via AIM to Arin@APR
Here are a few things to check:
16618/P0234/000564 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
Possible Symptoms
* Boost pressure too high
* Reduced power output
Possible Causes
* Hoses incorrect connected, disconnected, blocked or leaking
* Malfunction N75
Possible Solutions
* Check charge pressure control
* Check Solenoid Valve for Boost Pressure Control (N75)
Arin@APR is offline   Reply With Quote
Old 11-05-2008, 08:45 PM   #4
Colleton
Colleton's Avatar
OK, thanks for the help. We'll see what the dealership says tomorrow.
Old 11-05-2008, 09:22 PM   #5
Ducky 2.0T
FIA GT Champion
Ducky 2.0T's Avatar
Drives: N/A
I am also having a problem with my APR STG 1. I've had it at the dealer 2x now.
When I am WOT in 5th or 6th gear, the car goes into limp mod, but I don't get a CEL.
It throws a softcode:
000135 - Fuel Rail/System Pressure: Too Low
P0087 - 002 - Lower Limit Exceeded - Intermittent
Garnett has performed a few separate TSB's that they thought would remedy the situation. One for the Cam and another one. It is going in tomorrow with the hope of testing the LP and HP fuel pumps.. Hopefully one of them is the culprit.
I can not run WOT on the highway for fear of going limp.. Not an easy feeling when cruising at 80+ and the pedal is pretty much dead.
**Visit the WFSU Blog**
Ducky 2.0T is offline   Reply With Quote
Old 11-05-2008, 09:37 PM   #6
SoNgMaN
I Void Warranties
SoNgMaN's Avatar
Drives: 2010 4dr UG TDI HL
have you had the fuel pressure sensor replaced? i'm getting P0087 every so often myself. car won't boost past 7ish lbs when i have the code (not a true limp mode) car is producing the boost it's requesting. no MIL is thrown, as soon as i clear the code, car is back to normal. I'm having my Cam/Follower inspected next time i'm at the dealer.
SIGN MY SEARCH BUTTON PETITION - Hex-CAN usb Vagcom in the GTA i pwns all .::. KM Count: 140041
Originally Posted by SloppySRT View Post
give me a f!@#ing break, I've seen bigger tits than that in the kiddie porn I watch
187 WHP / 201 FT/LBS - bone stock - I have all this junk below now maybe i'm faster
::APR Stage2::Eurosport 3" DP::GT conversion::BSH DV::BSH stg2 PCV Fix::FK Silverline +X coils::Neuspeed P-Flow::30% tint::Forge FTB+STS short shift kit::Newsouth Boost Guage::BSH Dogbone Mount::textured mirror caps::smoked side markers::smoked mirror signals::sharan rep::Hoen Xenon Match Titanium::
SoNgMaN is offline   Reply With Quote
Old 11-05-2008, 09:56 PM   #7
Ducky 2.0T
FIA GT Champion
Ducky 2.0T's Avatar
Drives: N/A
Originally Posted by SoNgMaN View Post
have you had the fuel pressure sensor replaced? I'm having my Cam/Follower inspected next time i'm at the dealer.
These are what they replaced in the past 2 visits.. Each time I think it is fixed and I run strong as anything for a few days and then it comes back.
For now I am just pussy footing 5th and 6th gear, but I noticed almost all gears are not boosting like they did.
Old 11-06-2008, 01:39 AM   #8
SoNgMaN
I Void Warranties
SoNgMaN's Avatar
yeah i've been having a similar issue, i'm pretty sure it's cam/follower related but it is completely random, happened 3-4 times same day few weeks ago, hasn't happened since. I still drive it as i always drive it, 6th gear on the highway, WOT 2000-4500RPM. last time it happened i had the laptop hooked up took some logs. the car was requesting 7ish lbs of boost rather then the 24ish it normally requests. scanned, cleared the P0087 fault code, instantly back to normal
Old 11-06-2008, 02:26 PM   #9
Colleton
Colleton's Avatar
Ok, just got a call from the dealership, they said that they replaced the breather valve (PCV valve?) and the car is good to go.
I hope that was it. I had noticed a bit of oil on the engine cover by the cap.
I think maybe a BSH PCV fix might be in order soon.
Old 11-06-2008, 02:32 PM   #10
staulkor
V-Dubber
staulkor's Avatar
Drives: GTI MkV Fahrenheit #776
Send a message via AIM to staulkor Send a message via Skype™ to staulkor
I doubt the PCV was causing an overboost code...if the PCV leaks/blown, you are UNDERboosting, not over.
Mods: oem k04, revo3, giac dsg flash, BSH intake, 42dd race nonresonated dp, awe catback, fk highsport, defi boost gauge, euro led tails, plasti-dip grill, xenon match fogs+highs, DanGSR 28.5mm rsb, BSH DV, KMD Fuel Pump, 35% 3M tint, BSH mounts, Snow water/meth, forge twintercooler, BSH race catchcan, BSH throttle pipe, carpc and more!
K04 installed!
staulkor is offline   Reply With Quote
Old 11-06-2008, 02:36 PM   #11
07Noside
Your issue is fuel rail pressure. Unless you cam shaft is completely worn this will not cause an issue. Follower wear also has no bearing on a fuel rail pressure deficit, Unless you've punched through the follower and this would lead to complete and utter cataclysmic engine failure. Still you guys have had the TSB on the fuel sender etc and you still experience fuel cuts with software that requests 130bar fuel rail pressure on an OEM pump.
Old 11-06-2008, 04:33 PM   #12
SoNgMaN
I Void Warranties
SoNgMaN's Avatar
correct, I have never inspected the follower/cam. I've had the sensor replaced and the issue has only be since i went to H2Oi. I have a thread. I'm under the impression a worn follower can lead to issues with fuel pressure
Old 11-06-2008, 10:55 PM   #13
initialGTI
FIA GT Newbie
Drives: MKV GTI
I am going to say you have a leak. The dealer will not be able to replicate your problem with the stock program switched, so not sure if its useful.
2006 Golf MK V GTI [GT 3071R,Gruppe M Intake,RS4 injectors,USP LPFP,HPFP High Pressure Fuel Pump,3" Turbo back exhaust,Forge Intercooler + SPM Intercooler
,Stoptech brakes]
initialGTI is offline   Reply With Quote
Old 11-06-2008, 11:02 PM   #14
Colleton
Colleton's Avatar
Yeah, I'd come to this conclusion as well, but was unwilling to take it in running a performance program the first time.
At any rate, they did find a boost leak (the PCV was leaking internally and was replaced) and I had no issues on the ~ 45 minute drive home. I switched it back to 93 octane performance as soon as I left the dealership and drove with the DSG in Sport.
We'll see...
