The design of the underbody is 40 % of the total drag of a modern car !!
A flat underside will always reduce both drag and lift. So the stock underside of the GTI creates both.
Without a wind tunnel we cannot state the amount of improvement but it it will be
an improvement. Flatter is better in this area.
We cannot exactly state the resulting lift front and rear (but I promise at 200 km/h
it's around 0 front and 250 N rear). No real downforce of course, but better than stock though.
At high speeds ''
aerodynamic drag'' is the main drag factor. Reducing it by a low margin
has large effects on dynamics and economy. Also there is ''
aerodynamic lift'' causing
instability.
Lift isn't any problem the Golf's front. :wink:
It's got nearly no lift (about 50 N/5 kg @ 200 km/h) at front. The rear is an unequal problem
like it is with all hatches. The stock Golf V GTI produces about 350 N/35 kg lift @ 200 km/h,
the Mk.VI as well.
That's much more important because the cars's tail is lightweight and when braking hard it's
even much more light. Some of You may have experienced that by their own.
:driver:
Dont' expect wonders, but there's a slight improvement possible for very low budget.
There are some OEM parts from Audi TT, newer A3 and Golf BlueMotion that fit the
Golf V + VI GTI easily:
- larger underbody engine/gearbox cover (instead of smaller one, looks like TDI cover)
- small deflector between rear axle and muffler
- some smaller parts to come later (more complicated)
There are no downsides like higher Oiltemperatures !! I measured with the Kufatec
E-MFA an increase of oil temperature of just 1° C after full throttle for several minutes.
The engine compartment is also much cleaner since then. :happy2:
Note: only the ''... ... 237 P'' has three ''NACA''-style vents. Two for the gearbox,
one for the turbo.
Example Audi A3 (almost identical to Golf V/VI):
Between fuel tank an rear exhaust there's the ''Hinterachsverkleidung'' = rear axle cover.
Installation is made in 5 - 10 minutes each, plug & play !!
part number
1K0 825 237 P:
1K0 501 713 D Trim for Rear Axle:
There are even some more, but these are the easiest to install parts:
Engine undertray
1K0 825 237 P Noise Insulation £28.84
1K0 825 951 Hex headed bolt (Combi) 89p (need 3 according to above list)
Rear axle cover as fitted to bluemotion
1K0 501 713 D Trim for Rear Axle £26.73
1K0 501 682 Retaining bracket £1.89
N 905 483 05 Not on Stamm
N 901 838 02 Not on Stamm
Rear covers from A3 or TT
1K0 511 539 E Stone chip Guard £5.37
1K0 511 540 C Stone Chip Guard £6.75
8E0 825 267 a spreader rivet £0.12 (need 4 so x4)
Nr.12 is ''Hinterachsverkleidung''. 7 - 9 is mounting hardware:
Nr.1 und (1) are mor kind of ''all terrain protection'':
2a and 2b comes from Audi A3 and TT 8J (fwd only).
Nr.3 comes from TDI BlueMotion and is best to be used with an non-resonated exhaust.
Nr.4 is ''Hinterachsverkleidung'' from TDI Blue Motion.
