Unique garage door opener mod - Pics!
Roland R2.0T
Mod Maniac Veteran
So-Calif
2008 GTI
I have done this to my other cars because I can never find a really good spot for the garage door opener. I chose the spot in the overhead console between the things that look like speaker grills. I used 2 switches from Radio Shack (p/n 275-644) which are simple momentary pushbutton switches, they come in red also. I need 2 switches because I have a 3 car garage with 2 doors, the less fortunate will need just 1 switch. :wink: The opener will reside in the sunglass compartment, which is too small for any of my glasses, so it is expendable.
Disassemble the opener and solder 6" of speaker wire to the back of the operating switch, mine had 4 terminals, so be sure to test which are active by shorting them with a paper clip. Drill a hole(s) in the back of the opener, feed thru wires and reassemble.
I attached spade terminals to mine so I can remove the opener to change batteries, don't put them on the switches yet. Remove console panel by prying the left side and gently pull down the front of the panel, the back is hinged, so don't pull there, it will drop down and come right out, very easy.
Carefully mark the switch position, be sure to allow for the small front lip and the nuts that secure the switch. Drill the hole(s), it needs a 7/16" hole, but I used a 3/8" and finished it with a dremel using a sanding drum, start with small bits and work your way up. Mount the switches and hang the panel.
Drill a 3/8" hole in back of the sunglass compartment to feed the wires thru.
Snap the panel back in, crimp the lugs on and connect the switch(s) to the opener. Apply adhesive velcro the back of the opener and secure to the bottom on the sunglass compartment (I removed the rubber pad). I stuck a piece of foam in there to prevent rattles.
Sit back and admire your work, it looks factory. The job cost $6 and took 2 hours, assume half that for 1 switch. Enjoy!
pbfoot
USA
pretty cool, but why not just keep it in the sunglass holder? that's where I keep mine...
BodegaBay
NV
2019 Golf R
Not in the sunglass holder. I put mine in the ashtray compartment. Velcro to hold it upright. Out of sight and just pop the lid to access.
Nice mod above without having to spend $$ for HomeLink.
BOz
Keep right except to pass
Miami Beach
08' MKv GTI
i wish you could use one of the fake looking buttons next to the esp.... that would be cool....
Roland R2.0T
Mod Maniac Veteran
So-Calif
2008 GTI
You can. Try the sites that sell OEM parts, you can buy switches that replace the blanks, or you can save some money and drill thru the blank buttons and install the same switch I used, there is lots of room in the console to hide the remote. You can use remote light controllers too, turn on the house lights as you pull up. Remote shit is :w00t: !
Mpbsr
New Jersey, USA
Where from? How much?
If I recall, picked up the pair for under $50.
I also needed to do some wiring to the existing set up for the visor which ran about $30.
The Eos visor is a little shorter than the Jetta visor, but I was able to adapt. I heard the Passat 2004+ will also fit and some of them have the visors that can expand...so no adapting needed.
If you're interested please let me know and I'll look up the wiring kit needed. Same wiring kit for the Eos or Passat visor.
