dpham00
Modérateur Emeritus
- Los Angeles, CA
Well, i got the LCT unit installed today.
pic of the unit:
pic of the unit partially installed:
video (sorry, it's really really bad quality)
this is what they claim:
- display 0-60 mph time on the MFD (dashboard) in realtime
- display 0-90 mph time on the MFD (dashboard) in realtime
- display quarter mile time on the MFD (dashboard) in realtime
- display half mile time on the MFD (dashboard) in realtime
- display 0-100 kmh time on the MFD (dashboard) in realtime*
- display 0-140 kmh time on the MFD (dashboard) in realtime*
- display 400 metre time on the MFD (dashboard) in realtime*
- display 800 metre time on the MFD (dashboard) in realtime*
- display the absolute turbo boost pressure on 2.0t engines on the MFD (dashboard) - even while driving (specified boost only)
- display the relative maximum turbo boost pressure on 2.0t engines on the MFD (dashboard) in realtime
- display the actual o2-sensor (lambda) readings on the MFD (dashboard) in realtime
- allowing to select between 2-6 comfort blinks (factory is only OFF or 3) on either indicator
- automatically open/close the windows with the factory RF key remote
- adding a special indicator or horn sequence while you are in reverse gear
- adding Brake Light Assist
- adding Mirror Park Assist (flips down the passenger side mirror so you can see the curb)
- functions can be configured through our exclusive on dash menu via the MFD
- the module can be switched off to be completely invisible to any workshop
- works with automatic, DSG or stick shift
- easy installation - takes less than 10 minutes
- new installation harness for full plug and play: no wires to cut or splice!
- new dual core processing power
http://store.l-c-t.com/merchant2/me...&Product_Code=golf_vcm_ultra&Category_Code=VW
i believe the boost shown is spec'd tho, and not actual.
pic of the unit:
