kruegernaut
I'm from Detroit, Man...
- Washington
Below is what I replaced doing springs, shocks and struts. If you are doing sways, I can get you that list too. I should note here, I did not remove my front axle bolts when doing the install. Some DIY's do this and some don't. If you do remove your axle bolts, it is advised that you replace those too.
FRONTS
--TT strut mount kit X 1, came with bolts for mounts and locking nuts for top of strut. (I did not use the top nut that came with the Bilsteins for the fronts, I used what came in this kit.) http://www.ecstuning.com/ES2627431/
--Pinch bolt and Nut X 2 for strut to spindle. http://www.ecstuning.com/ES6054/
--Ball joint to LCA Nut X 6. http://www.ecstuning.com/ES6053/
--End link Nut X 2 for where end link attaches to strut. http://www.ecstuning.com/ES7321/
REARS
--Shock to wheel bearing housing and upper shock mount to body bolt kit X 1. http://www.ecstuning.com/ES250812/
--Lower control arm to wheel bearing housing bolt X 2 and Nut X 2. http://www.ecstuning.com/ES468680/ http://www.ecstuning.com/ES5835/
--Upper shock mounts X 2. Dont get Vaico... If I were doing this over, I would just get OEM. http://www.ecstuning.com/ES250671/
FRONTS
REARS
