ja-gti
Rollin'
- Hello Cleveland!
So I've been following the threads about worn cam followers, and was persuaded to change mine out at 32,000 miles. Some have argued that it really is unnecessary to change it, and that the followers that have failed were just a batch of bad followers that got into our engines.
I had a micrometer laying around, so I measured the wear of my old follower versus a new one. (Both measurements were made in the center of the CF).
I'm hoping some actual measurements will help solve this problem, and give more info than looking at pictures of wear on the CF.
1.Left - new CF
Right - Old follower (32K and almost four years old - and I make a lot of short trips in cold weather). DLC is gone, but very even wear.
2.Old follower -777 microns (conservative - I'd guess it's really close to 777.5)
3. New CF -781 microns
Total wear over 32K miles is a grand total of 4 microns. That rate of wear should give you well over half a million miles before you've lost more than 10% of the total thickness of the CF. (4microns of wear/ 32K miles. 10% of 781 = 78. 78microns/4microns x 32Kmiles = 624K miles for 10% cam follower wear.)
While the loss of the DLC may increase the rate of wear, I don't think it is going to increase the loss of wear so fast that the CF will fail under 100k miles. Plus, these engines are bench-tested for thousands of hours, representing hundreds of thousands of miles, and a design flaw as significant as is being reported should be easily evident.
I think a supplier screwed up and delivered some soft metal - and some of us are paying the price, and the rest of us don't know who will be next.
I'll check my new cam follower at 60K miles, and if the wear is similar to what I've reported, I'll just keep that CF in there.
Hope this info helps some folks out.
1.Left - new CF
