jaycheetwood
- where it snows
UPDATE:
Port and polish job is complete and I got the car back.
results. in 6th gear where i would spike at 20 - 21 psi i now hit 24 - 25psi with no retuning and boost adjusts on my revo settings. The car pulls much harder and much smoother and at 6000rpm im still at 16psi which is up from the 14psi i was seeing. I hit higher boost in all of my gears now averaging 23psi spikes and where i was holding 15psi i am at 16 - 18psi.
The work was done by a great guy out here and is just awesome the whole car feels much more smoother and hits 23psi and holds that for far longer than i ever held just 20psi.
I will have it dynoed hopefully this week for numbers and things of that nature.
Pics:
Enjoy. Best $200 i spent yet.
OP:
Has anyone done this to their turbo?
I have a friend with an extremely custom evo who does machining and he said he would port my k03 and make it far more effiecent and make it flow more air. Is this possible?
He also thinks that if i completely port the turbo and then machine it and put in k04 internals i will see great results and alot more power as the turbo can move more air.
Everyone says the k03 down fall is air movement. Well if I port it i can get more air and more flow for better effieceny correct?
Any thoughts or ideas? Maybe even porting it and using different k03 internals than the current ones..
Pics:
OP:
