This link is a thread created by
DanGSR titled
'review: EVERYTHING':
http://www.golfmkv.com/forums/showthread.php?t=65289&highlight=dan+gsr
DanGSR builds race cars & motors and is a wealth of knowledge on all aspects of the Golf MKV; not to mention highly respected by forums members including me for the time he takes to assist others in their quest for knowledge.
If you pay particular attention to the comments that DanGSR makes in respect to the JIC-CROSS COILOVER that he has installed in his MKV GOLF, you will see that he does not recommend them for street use. Neither do I. Why?
1. 15 way damper adjustment does not appear to be independent (separate compression/rebound adjustment like KW). Better check if the rear damper is inverted on the JIC-CROSS. With my KW V3 kit: I have the ability to crank up the low-speed compression rate only & total rebound separately. This allows me to either have a race car high low speed compression rate for track, but still have a factory pre-set high speed compression rate for when I drive home from the track and encounter large high speed compression bumps/dips/potholes; and vice versa - I currently have my KW V3 low speed compression (and rebound) set on almost full soft for a nice ride in town and on B-grade tarmac, with the advantage of a factory pre-set KW high speed compression rate to prevent the damper/spring from bottoming out and striking the bump stop (as may be in the case of the PSS9/10 when set on full soft) - this is a major advantage for a street driven vehicle imo.
2. Pillow ball upper mounts are very noisey - create banging as the metal of the pillow ball impacts against the chassis.
3. Camber adjustment is a bonus - but with 20mm lowering, you should receive @ addition -1 neg of camber. This will help handling in cornerns. To save on inside of the tyre wear, you may have to adjust the toe, esp if doing long straight freeway drives with minimal corners. This may detract from turn-in response.
4. Helper Spring - another area weer noise may be apparent - once helper spring is completely closed, the two metal plates may bang together creating more noise. KW does not use helper springs; rather using linear cone shaped single spring for the front of MKV. In addition: Helper spring compresses under body weight of chassis, extending if you jack up vehicle or get airbourne to help keep the spring from unseating itself and popping out - similar effect to the closely spaced springs in the Eibach ProKit/Sportline/H&R Sports also creates noise (spring bind noise in this case).
5. Adustable Lower Bracket - does reduce bump stop impact on full compression. Very rarely will you hit the bump stop for street driving. My last Eibach ProKit/Koni-FSD kit, the bump stops were like brand new; despite bashing it over runs like Waterfall or in the country out to the farm.
6. Linear Spring - Linear spring provides create feedback & control for the chassis & driver. Makes for a crap ride on the street; great for race track. In addition: JIC-Cross spring rates are not only linear; but tend to be at the higher echleon compared to other coilover brands - makes for even worse ride.
JIC-CROSS are great for track; not so good for a street driven vehicle.
If JIC-CROSS were good for a street driven vehicle; I would have them on my ride.
Dan_GSR does not recommend JIC-CROSS for a regularly driven street vehicle; neither do I.
Cheers
WJ
