I just got the car up and running and I noticed in the logger the car pulls 12 degrees of timing after it warms up. (Never did this before) It does this pretty much in any engine load, rpm, and gear. I spent the weekend trying to pin point where but pretty much anything over 10% throttle once warmed up, it pulls 12 degrees across all 4 instantly and never adds timing back. There is no codes, plugs and coil packs are fresh, even did a compression test and it came back with 198 across the board. I haven't touch the knock sensor as they aren't known for failing. I also just changed the TB as it failed recently. Car runs on maestro, forged internals, rs4 injectors, 3076. Any help is appreciated.
