Timpanogos Slim
- Hurtling up and down I15 in Utah
pressure relief valve is just like a tire valve, on the right hand side of the pump as you stand in front of the engine.
Check valve is what the hard fuel line attaches to.
Dunno why you need a crow's foot. 17mm monkey wrench is what works for me. You also should not need to remove this part. You just loosen it a little. And tighten it back up.
I had to remove mine to remove my pump so i could take it in for an upgrade. The spring clamp's tabs were on either side of the check valve so i figured i would just take off the valve, and forgot about the crush washer.
Make sure there are no nicks or dings or debris on the ball at the end of the fuel line or in the cone of the check valve. Those are where it seals. This is a high pressure connection so it will leak if there is any damage.
You can replace that fuel line but it looks like a huge pain in the ass to me.
