SALE: NEUSPEED High Flow Turbo Discharge Conversion Kit for 2.0T BPY - $149.95!
MJM Autohaus
GolfMkV Sponsor
T E X A S
The NEUSPEED Hi-Flow Turbo Discharge Conversion Kit includes all the parts needed to remove serious restriction from the discharge side of your turbo. First, a newly machined billet aluminum discharge adapter reduces restriction with its smooth bore. Unlike its OE counterpart, the new adapter reduces turbulence and reversion. Paying close attention to detail is what NEUSPEED has always been known for and it doesn't change with this piece. Take notice of the machined lip on the mounting flange that ensures leak free performance. Secondly, a new silicone hose is included to mate the new discharge adapter to the next and most important item in the kit, the modified OE discharge pipe.
The OE discharge pipe starts off at 38mm inside diameter and gradually increases to 57mm inside diameter. NEUSPEED then cuts the original pipe at the point it reaches its maximum diameter and rolled a lip to make securing the silicone hose easy and trouble free. Consequently, all restrictions are removed with the kit's full diameter flow. All these benefits are attained with no modifications to the vehicle - this is a simple bolt-on part. With this kit installed, you can expect better response with less turbo lag and more horsepower.
NOTE: Please note that this part fits a specific VIN range of cars. We ask that you be thorough in selecting this product for your vehicle in attempt not to lose money from shipping or restocking parts. This part only fits up to specific VIN ranges in '07 GTI, '07 Jetta and '08 EOS and Passat models. GTI VINs up to 1K_7W129620; Jetta VINs up to 1K_7_191156; Eos VINs up to 1F_8_001500; Passat VINs up to 3C_8E137353 and 3C_8P076055. For '06-'07 Audi A3 and '08 Audi TT built after 9/03/2007 and for '07.5 and up GTI and Jetta, '08 EOS and Passat with VIN after this range, please use part number 48.02.67. Another way to determine if this part is correct for your vehicle, you will need to look at your original discharge pipe. If the locking notches for the pipe's retaining clip are located at 12 o'clock and 6 o'clock positions, this is the correct part. If your OE pipe has retaining clip notches located at the 9 o'clock and 3 o'clock position, please use part number 48.02.67.
Fits:
* 2006-2008 GTI 2.0L FSI (BPY)
* 2007-2008 EOS 2.0L FSI (BPY)
* 2006-2008 Jetta 2.0L FSI (BPY)
* 2006-2008 Passat 2.0L FSI (BPY)
* 2006-2008 Audi A3 2.0L FSI (BPY)
* 2008 Audi TT 2.0L FSI (Before 9/03/2007)
- $259.95 with free shipping!
To place your order, click ---> HERE (ALL KITS SHIP SAME DAY).
