I am now running 225/45/17 on standard 7.5'' GTI rims wich was a much better setup for track than my first 235/35/19 Goodyear F1 Asymmetric street tires. However, in about 2 weeks I'll be installing 6POT 362x32mm AP Racing brakes wich will require 18'' wheels. As I'm gonna buy these anyway, I was thinking of going 8.5'' (instead of 8'') wich will allow me to run 235 and 245 tires as recommended by Toyo, Kumho...for semislicks.
The data to take into account for this choice will be :
1) 370HP/475NM
2) 1450-1500Kg including driver & gas
3) TT arms in front wich throw the wheels about 7-8mm out of the wheel arch with 235/35/19 on 8.5'' rims
4) 245 tires may cause rub on the rear
Tire sizes/recommendations from different manufacturers :
Tire size > Overall diameter > Overall width > Tread witdh > Optimum rim width > Rim width limits > Sidewall height (given by tyre calculators) > Difference in diameter from stock tire (recommended <3%)
Kumho V70a
225/45/17 > 628 > 224 > 207 > 7.5'' > 7'' - 8.5'' > 101.09mm > 0% (stock size)
225/40/18 > 631 > 229 > 212 > 8'' > 7.5'' - 9'' > 89.92mm > 0.44%
245/35/18 > 624 > 251 > 234 > 8.5'' > 8'' - 9'' > 85.60 mm > 0.89%
Toyo R888
225/45/17 > 635 > 231 > ? > 7.5'' > 7'' - 8.5'' > 101.09mm > 0% (stock size)
225/40/18 > 637 > 224 > ? > 8'' > 7.5'' - 9'' > 89.92mm > 0.44%
235/40/18 > 648 > 244 > ? > 8.5'' > 8'' - 9.5'' > 93.98mm > 1.70%
245/40/18 > 653 > 249 > ? > 8.5'' > 8'' - 9.5'' > 97.79mm > 2.88%
Yokohama A048
225/45/17 > 632 > 226 > 223 > 7.5'' > 7'' - 8.5'' > 101.09mm> 0% (stock size)
225/40/18 > 635 > 231 > 216 > 8'' > 7.5'' - 9'' > 89.92mm > 0.44%
235/40/18 > 645 > 244 > 226 > 8.5'' > 8'' - 9.5'' > 93.98mm > 1.70%
Dunlop Direzza 03g is too expensive and I can find no sizes on the internet. As you can see, for 235 &245 tires, the optimum rim would be 8.5'' and the minimum 8''. As I said on point 3), my 235 tires on 8.5'' rims stick out of the wheel arch about 8mm due to the TT arms so running 235&245 tires with 8.5'' rim will require new wings (Kerscher wings are about 20-25mm wider so they give plenty of clearance for these tires). As the price of the 8'' vs 8.5'' rims will be the same (TD 1.2 pro race) and the 225 vs 235/245 tire will also be similar, the only added cost will be the Kerscher wings at 650 Euros + painting (another 200 Euros). The final question is if the added grip of 235/245 tires over 225 deserve the extra money for the new wings. Aslo, I would like to have enough sidewall to properly help the suspension over bumps (245/35/18 seem to lack sidewall here) but not too much to avoid flex (245/40/18 has the biggest sidewall but still smaller than 225/45/17)
PS : As you can see, for the same size, there are great variations in overall width and tread width between various manufacturers !
Hopefully you'll have the patience to follow this topic and will also help you guys in the future choosing tires/rims for our mk5 chassis !
1) 370HP/475NM
Kumho V70a
Toyo R888
Yokohama A048
