I received a PM from a member regarding this feature; he had spotted an old vortex post that I had made about. Just to clarify, I did not discover this, I read about it and posted some concise instructions on how to do it through VAG COM.
In case you're not familiar, VAG COM is a diagnostic tool/software that allows control of many aspects of your VW; turning off DRLs, for example. For this feature, the car utilizes the rain sensor in the rear view mirror and puts up the windows and closes the sunroof at the the first sign of moisture. I did this mod last week for a local member and we got on the subject of how sensitive the sensor is-a licked finger over the sensor closes it up, which is pretty damn sensitive!
Here are the instructions again for anyone with access to VAG COM for their US Spec R32. Use at your own risk-don't proceed if your original values are different than mine, write down all your original values, etc....
Part No: 1K0 955 559 AF
Component: RLS 260607 046 0204
Coding: 00207646
Shop #: WSC 05055
I changed 00207646 to 00469790.
And then under 46 Comfort System Controller I set Byte 09 from HEX 04 to HEX 02.
At that point I had a menu in my MFD under Convenience that allows for Rain Closing either On or Off.
Here are some screen shots of the MFD of this feature.
Coding: 00207646
Shop #: WSC 05055
