POLARBEAR666
- Australia
This is FYI of what I have done, seek your own professional advice before attempting it yourself at your own risk.
I will answer any questions if anyone posts them.
ps: the green and yellow refer to the squarish plastic assembly that is bolted in middle of engine top and hooks up the Red , yellow and green connections via a single plastic body with one way valves built in. You just ditch this and screw the N249 solenoid (not sure exact number) down using the screw and hole that used to hold the whole plastic assembly down, then connect the boost reference feed (GREEN) directly. :happyanim:
