Old parts:
VF Intake - OUT
Battery box - OUT
New parts:
BSH Intake - IN
BSH V-Twin - IN
BSH Engine Mount - IN
Eurojet DV Re-Route Kit - IN
Eurojet Throttle Pipe - IN
Eurojet Engine Ampification Pipe - IN
Eurojet Heatshield - Pending
This post is my personal opinion only so :middlefinger:
OK guys! Heres the review for the following parts:
BSH Intake
BSH Engine Mount
BSH V-Twin Boost Tap
After months of waiting, hours of swapping parts, and frustrations... The upgrade is finally completed! The whole process took so long I was thinking was it even worth it! But after the long driving tonight, I can say it is all worth it! So this is the review in short!
OK now to the long review (reading this part is optional - WARNING might bored you to death or might cost you a dent in your wallet, result might vary read at your own risk ):headbang:
When I first drove im like where did the boost go? My car feels like a solid NA engine! The power delivery comes so smooth that i feel the car is slower! No more feeling of that slight turbo-lag! Its GONE, I believe this is the benefit of the larger Eurojet Throttle Pipe which has lets bend and no reduce size in the middle of the pipe! The throttle response is like NA now! Crazy!
Second thing I felt was the change of the front end of the whole car! It came together as one piece handling seems much more stable as well! While I was doing the mountain pass lift throttle brake throttle brake felt the biggest difference! No more play in between, the car is much more controlled! I thought ppl was BSing about the engine mount! IT WORKS... yes you may feel more of the engine or the transmission but I liked it! I can even feel the brake pad movement when it clicked on reverse which I have never felt before on this car! Oops almost forgot! after flooring so many times on S gear especially going up hill wheel hop problem seems to have reduceds significantly
Then the third thing is my turbo boost reading showed on my Defi boost gauge! The peak shows about 1.25bar! DOESNT EVEN HIT 1.3bar! GOOD NEWS No more stupid boost spike! before with the Forge DV my Defi shows almost 1.4bar! My Unitronic Stage 1+ chip requests 18PSI which is about 1.24105631Bar, so with the Eurojet DV reroute kit solved my boost spike problem! It open and closes much faster than my Forge DV, sounds much cooler too like a proper big turbo wastegate sound! WOOOOSH ! I have set my Defi peak warning to 1.3bar and it has never beeped once tonight! (reminder my Defi doesnt rest at zero when its off! it rests slightly above zero due to defact product from TopRacing) So the whole night I have been using mixed shifting modes D, +- Manual, and S mode flooring here and there redlining... Nope didnt hit 1.3bar! No more Boost Spike!
So as a whole I feel that my car now is much more controllable than stock even its chipped! Smoother power delivery and better ride and handling than stock with all the mods I have done (read my signature for the complete mod list) So I think I will take a break on the modding with this car and focus on my other project And also just enjoy driving and maxing out the car as often as I could!
And finally!
Thanks to :bow:Shane at http://www.monstergarage.com.hk/ who had help me throughout the whole process!
VF Intake - OUT
Battery box - OUT
New parts:
BSH Intake - IN
BSH V-Twin - IN
BSH Intake
BSH Engine Mount
And finally!
