blue32
- fort mcmurray alberta
Hey guys here is a DIY for doing a remote starter in an 06 jetta......iphone pics sorry poor quality
Step 1: Push in light switch from the off postion and turn towards the on switch and the switch should pull out and remove screw
Step 2:Remove panel underneath by OBD plug there will be 2 screws down there
Step 3: If the car has a driverside glovebox push on the left side of the box and gently pull towards you panel will pop off ...remove screws underneath pocket
Step 4: Remove screws in the tiltleaver to remove handle and there will be one more under the leaver as well
Step 5: Gently pull trim peice off of the top of the sterring colum plastic there will be a screw to the left holding the panel with the pocket on last screw for the side now the panle will be removable..
Step 6: there will be 2 more screws underneath after you take the top of the sterring wheel colum off one on the left one on the right and the colum will come off
