MK8 Golf R chassis & brakes part numbers
greekspec2
California
17 Golf R 17 BMW X1M
Thought I post some part numbers from a MK8 Golf R DSG .... the front hubs have a little more camber, stiffer sway bar and RS3 control arms. The rear uses stiffer bushings and a bigger sway bar.
FRONT
5WA407253B left wheel bearing housing
5WA407254B right wheel bearing housing
5WA407621A wheel hub with bearing
81A407151F left track control arm
81A407152F right track control arm
5Q0411303AC stabilizer 25x4
5WA411105A front coil spring
5WA423811D left tie rod end
5WA423812D right tie rod end
5WA199369A subframe
5WA413032T electronically shock absorber
1K0412303E bump stop
REAR
5WA511305L stabilizer
5WA505465A connecting link
5WA511115C coil spring
5WA505311A track control arm
5Q0505323C camber track control arm
5WA505435G left wheel bearing housing
5WA505436G right wheel bearing housing
5G0501529G tie rod
5WA513045BB electronically shock absorber
5G0513353G shock absorber mounting
5Q0511357S bump stop
BRAKES FRONT
5WA615123BSQ5 left brake caliper blue
5WA615124BSQ5 right brake caliper blue
5WA698151B brake pads
5WA615301A discs 357mm
5WA615311A left splash shield
5WA615312A right splash shield
5WA611701 brake hose
BRAKES REAR
5WA615423BSQ5 left brake caliper blue
5WA615424BSQ5 right brake caliper blue
5WA615425BSQ5 caliper carrier blue
5WA698451A brake pads
dcgtimk7
DC
FRONT
5WA199369A subframe
REAR
5G0501529G tie rod
BRAKES FRONT
BRAKES REAR
Sweet! Do you know the part numbers for the clubsport's brakes?
burgerkong
Ontario, Canadeh
FRONT
5WA199369A subframe
REAR
5G0501529G tie rod
BRAKES FRONT
BRAKES REAR
Should be the S3 lower control arm, not the RS3. The RS3 shares the same arm as the TTS/TTRS which are aluminum with greater track width and sliding BJ's.
GolfRRRR1
Michigan
Does anyone know if the MK8's larger brakes fit under 18" wheels? May be a factory upgrade...
dcgtimk7
DC
yakev724
NYC
2015 S3
mk8 floating caliper might still be inferior to macan/megane fixed brembos at similar price point new
curious about the knuckles, have a pair of alu lower control arms waiting to go on, maybe worth pairing with these if they'll bolt up...
jmblur
Massachusetts
2017 Golf R
Part number of brake MC? Wondering if they use a larger one.
Also @yakev724 , got a part number for that megane brake? I wonder if they use seals that don't pull back so far or different piston sizing...
yakev724
NYC
2015 S3
410010873R
410116043R
more info in this thread
These require brackets (freakyparts.co.uk sells them), lines (custom made by HEL for example), 7mm spacers to clear stock wheels.
I believe the Megane shares the MC despite these being 4-pot, the piston surface area isn't too different.
Generally much more of a headache than the more common OEM+ upgrades.
The Fed
Old Guys Rule
Florida
OP, great info! I take it the brakes you listed are the "standard" MK8 brakes? I think there are optional 15" Euro performance brakes we probably won't get in the U.S.?
Can I figure the front calipers and rotors will fit under the stock 19" R wheels?
I never hear of anyone needing to change any hardware or ECU settings to accommodate larger front brakes to balance the front to rear bias. Is that totally unnecessary with the improvements in technology?
dcgtimk7
DC
The brakes listed are the 2 piston calipers with 357mm rotors. Yes they will fit under your 19” R wheels without a spacer.
