After about two hours of driving I parked the car on saturday afternoon on a very slight incline, enough steep so the car rolls back very slowly when in neutral. Not my normal parking sopt. During the night the temps dropped down to about ~11 deg from ~20 during the day.
The next day temp went up to ~30, and around noon I went to fire her up. Took longer than usuall to get her going and immediately the engine reved up to about 2k and dropped down way below 1k shaking violently and choking, finally it died. Fired her up again, same thing, but this time it will bounce between below 1k to above 2k trying to keep revs and not dying again. Looked at the boost gauge and it way bouncing from ~22 in Hg to ~10 in Hg. Died again. Third time it got somewhat better, but the engine was still shaking, revs slightly above 1k, 10 in Hg. Sounded like it was runnig only on 2 cylinders or so, basically missfiring a lot. No CEL throughout the entire happening.
Had to go somewhere and took my brothers car. About two hours after that I fired her up again, no problems. I let it sit to warm up a bit, and took it for a spin, no issues. Floored it a couple of times, no issues, normal boost. Wtf?
Today no issues at all, but while idling when I rev it up to over 1.5k it backfires more than usuall.
One day before, on friday, I filled her up at different station, still at Shell. Im at almost 62k, APR Stg 2 93 oct, intake, catless dp. Changed cam follower last summer and plugs about year and a half ago, at ~40k IIRC (stock Bosch), didnt touch pcv or coil packs.
I red a couple threads about misfires and similar issues, and want to make sure Im troubleshooting correctly.
-bad gas (?)
-bad coil pack(s)
-bad plugs
-clogged injector(s)
-carbon buildup
-temp(???)
Sorry for the essay
Any thoughts and help would be appreciated, thanks.
-bad gas (?)
-bad coil pack(s)
-bad plugs
-carbon buildup
-temp(???)
Sorry for the essay
