I wanna pull them for the tinted one.....thanks for the info guys!
ShadowGLI said:1: turn your mirror (glass) as far in as possible
2: pull gently on the corner of the lens to remove it from the housing
3: unplug it
4: remove all the torx bits you see(3 surronding motor-remove motor)
5: starting from the bottom out pull up and out till the top pops off(if you push mirror housing forward you can grab inside easier)
6: unplug marker harness
7: remove remaining torx bits (this maybe 6 i don't really remember)(Only 2 holding marker)
8: reverse
