Well, i've managed to get a MFSW for £75 second hand which i think is'nt a bad deal.
I'm guessing i will need to add a module and harness but cant find any info on the web, any ideas?
Hi,
I cannot answer the original question with 100% certainty (based on personal experience) since my Mk6 came with MFSW. I can say that I've answered emails worldwide from Mk5 to Mk6 retrofits and nobody has mentioned any actual Airbag replacements. ( they look identical IMO too )
Generally speaking, the address 16 - Steering Wheel Module that was installed in a car without MFSW would not support the coding or needed internal hardware. This page should help clarify the various modules:
http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions
If you have a complete Auto-Scan to post from VCDS, please do so before removing any components. This will help determine what module(s) are currently installed and where the G86 (steering angle sensor) is actually mounted. (The linked list and the LIN versions will make more sense at that point also)
-Dana
P.S. If the MFSW for £75 is from a Mk6 (12 button, LIN 2.0) with the module and switches all installed...you did real good on that price :thumbsup:
Hi,
-Dana
Hi Dana, had my local mechanic scan my car on your advice (greatly appreciated) and the module that is fited is 1K0953549CQ. Would you know if this will supprot adding a MFSW to my car?:thumbsup:
So if I purchase a MFSW without an airbag, I can use my airbag from my previous steering wheel?
My 2.5L Golf started with a non-MFSW:
http://lh5.ggpht.com/_TP9A_TQ7hvU/TOIGSeFl8tI/AAAAAAAAATs/DrfNFsyW6tI/s640/DSCN0606.JPG
The airbag can be reused in a MFSW. I upgraded to a GTD wheel with paddles. My SWCM was "CP" version and I upgraded to a "CD" version in order to get the buttons and paddle working via vagcom. Steps and some links to DIY:
# http://forums.vwvortex.com/showthread.php?2938601
# http://www.myturbodiesel.com/1000q/a...wheel-swap.htm
# SWCM upgrade (part # 1K0-953-549-CD) from eBay
# I got the MFSW from a salvage shop in the UK via eBay (came w/o airbag)
# The stock Golf airbag fits the GTI-style flat bottom wheel perfectly
# I also needed a new wiring harness since the original wheel wasn't a MF (part # 5K0-971-584-A)
# Vag COM and everything integrated perfectly with Tiptronics, RCD510 and 9w7
# My MFD was already the highline version and I have the wiper stalk with the MFD controls
New wheel:
http://lh3.ggpht.com/_TP9A_TQ7hvU/TO1Y36F-F6I/AAAAAAAAAVA/BhdvasxPKNM/s640/IMG_2237.JPG
Pic of the SWCM in the steering column:
http://lh6.ggpht.com/_TP9A_TQ7hvU/TOIGX7csukI/AAAAAAAAAT8/baTz-JUu-Uw/s640/DSCN0610.JPG
After you install the new SWCM, you will need to recalibrate the angle sensor. You can follow the procedure from the Ross Tech site:
http://www.ross-tech.com/vag-com/cars/steeringangle.html
Hope this helps. I would have been happy with just the wheel upgrade w/o the buttons but it turned out that I got a great deal on the salvage wheel so I spent a little more money to get the SWCM and wiring harness.
New wheel:
Dana, i've got my steering wheel and also understand i need a new wiring harness. I will also need to change the steering wheel module, could you tell me which part number this will be.
I am looking to upgrade my midline MFD to a highline in the near future, will this affect which steering wheel module i need to go for?
I'm still confused over this steering wheel angle sensor issue, will i have to change this as well or just make sure i purchase the correct steering wheel module to make sure they are compatible?
Thanks in advance as i know i'm asking a lot here but it is really appreciated.:thumbsup:
