POLARBEAR666
- Australia
The remaining screw holes are for my slimline number plate. Outer dealer drilled plug holes filled with bondo.
Hours and hours and hours and hours and hours of teaching myself to prep and practicing painting and redoing over and over. Now I have it down pat.
Paint in one motion from side to side perpendicular to the surface. One long stroke from outside of the object to the other side of the object finishing your stroke past the edge. Start from that side spraying before your reach the edge so that you are always already spraying when you start to pass over the surface to be painted.
Duplicolor Gloss black
Duplicolor Clear Closs
Red pinstripe tape. Gloss over top of it.
Cheers
More pics to follow once its fitted. Also modded my badge so that its got a white backshadow, white bezel ring and black outside ring and black emblem as some others have done. Should look trick!:thumbsup:
Cheers
