whether the wipers keep moving or stop when the car is not moving depends on the wiper setting that you have on...
if you have the wipers set to intermittent... when coming to a stop, i believe they will stop moving...
At the intermittent setting they will remain at the same setting whether moving or stopped.
if the wipers are set to the continuous operation on the lower speed... when the car stops, the wipers will move intermittently...
Correct.
when you have the wipers on the highest setting, they will keep moving no matter what the car does
When wipers are on their highest setting and you come to a stop, they will adjust to the slower continuous setting until you reach a speed of over 5mph again when they will resume operation on the highest setting.
I think the wiper system works great and is simple to use, much better than the one on my fiancee's brand new Mini Clubman (she has high, low, and a fixed intermittent setting which is never fast enough or slow enough so it's pointless).
As far as the OP's compalint that when the wipers are accidentally left on, in their low or high setting, when the car is started again they resume in their full low/high speed.... next time just remember to turn the wipers off and you won't have the problem :thumbsup: It works the same in the reverse, if you're sitting in your car not moving and turn your wipers on to the low or high setting, they will go on at that setting even though you're not yet moving not at the slower speed which happens after you come to a stop.
