[HOW TO PATCH Component Protection] MIB2 Technisat/Preh Headunit Patch(gps headunits only with 2 sd card slots)
Paul_K
CZ
Golf MK7 Variant
Thank you for the detailed explanation.
As my unit got stuck on ("Device is not ready. Software update is not ready. Please wait... It can take 10 minutes"), I should try to get into recovery menu and try to restore stock firmware.
Emergency recovery was successful. Thanks MR Fix for web content.
fitocar
ARGENTINA
Hi. Can someone help me activate Car menu (Vehicle status, driving school mode, etc..) on MIB2 STD SW 0480, H 41 . I already have offroad icon in the main menu (which works). I installed toolbox, patched CP and SWAP. Tried to change some adaptations in 5f module but with no success.
Car is Passat B7
Hi Ivan I'm Roberto from Argentina the same problem with my unit any solution for this questions?
Please @mr-fix can you help us ?
baldybouncer-
Wrexham North Wales
Golf mk7+ Golf mk8
New member here - so be gentle :)
I am looking at upgrading my daughters golf 2015 to MIB2 and have screen on order and USB etc... I did buy a MIB2 unit but got the wrong one! - Can anyone advise the part numbers of the NAV MIB2 unit I need to be looking to buy? It's so confusing - Thanks in advance
azza2
Asia
Golf6
If you are going to upgrade beyond 02xx, go with the highest: P0480T
Going from 02xx to 03xx or to 04xx requires the same steps and the same risks.
Not sure about grid in 03xx, but 04xx has it for sure.
Changes between 0254 and 0480:
  • Support for facelift glass displays with APP buttons,
  • GEM version 4.11 with touch screen navigation support,
  • Support for VC/AID (Virtual Cockpit / Active Info Display),
  • Support for new USB HUB,
  • Updated graphics with facelift car models (CAR, AUDIO, CLIMATE menus),
  • New skin layouts (grid) and new system-wide color theme,
  • Refreshed VW startup animations and new trim options (beatsaudio, FAMILY, Elegance),
  • Skin and startup animation for MAN vehicles,
  • 6 presets in Radio section if 8-inch display skin selected,
  • 6 favourite contact in Phone section if 8-inch display skin selected,
  • Media covers higher resolution support (needs to be confirmed),
  • CAR menu selection is remembered after switching ignition off,
  • Oil temperature gauge (SportHMI and Offroad) without red zone and rescaled for 100°C in middle position,
  • Start/Stop option to disable system status popups,
  • Air Condition option in main menu,
  • VW Media Control option in menu,
  • Configuration Wizard in Settings,
  • Traffic menu with map preview,
  • WLAN media source option,
  • 4 clock faces selection in standby,
  • Sound type displayed on the OSD when adjusting volume level,
  • Updated SFX when touching the screen,
  • FEC/SWaP hidden menu available without active developer mode,
  • Testmode menue available from hidden menu (3 seconds press instead of 10 seconds press),
  • FEC/SWaP code 00070400 for in-car communication is supported,
  • Testmode menue touch screen diagnostics no longer works,
  • Left and right speaker channels are inverted,
  • New adaptation channels (Key_code_monitoring, Vehicle function list BAP 2nd generation, expansion, Deactivation/activation of the pop-up for active tracking services, nhtsa_properties),
  • New cpu modules (fpkimagetransfer, i2cbridge, nuanceres.arw_EU).
Hi, how to use WLAN?
I got a unit with 0478T firmware and GEM 4.11t. The all options about WLAN seems grey and cannot be clicked in the menu or UI of mine.
Then I updated it with MIBSTD2_Toolbox-v1.4. All the opeartions about WIFI/WLAN seem like still grey and cannot be clicked.
I can see there is "MAC-WIFI:" on the label on the unit. And the "MAC address" of "internal WIFI module" in GEM is "00000000...".
What is the prolem with my unit?
azza2
Asia
Golf6
I figured it out. Unit must connect to CAN, otherwise Bluetooth/WIFI will not work.
Paul_K
CZ
Golf MK7 Variant
Hi. I am about to sell my Technisat mib2 unit, used toolbox to remove CP.
I have connected the unit into my friend's Tiguan mr2016, it was showing component protection message on the screen for a few minutes, than it disappeard after a while. Seems it works well (gps, buttons, map, bluetooth), but seeing some component protection message through vcds. Is it normal or something is not right? Thanks.
