How do you know your N75 or wastegate actuator diaphragm is damaged?
I have been trying to help another GTI owner in our Tuner Club with boost issues. His data shows that actual boost does not reach specified until rpm's go over 5200 regardless of preload on the rod adjustment. Once boost is met with desired/specified, beyond 5200 rpm, his specified is 2.0 bar(minus atmosphere) and actual can remain above desired boost. His actuator rod spins quite easily when I was adjusting it with vise-grips attached to the rod and so I suspect the actuator diaphragm is damaged. Have any of you gone through this exact process? And, am I on the right track suspecting the actuator diaphragm?
I asked my Tech if he can test it and he can. He also said it doesn't matter whether he applies pressure or vacuum to do the test. Is he right? Or do I need to determine which will perform the test appropriately?
Points to consider:
I found no leaks
N75 should be in good nick given it does create boost
DV is not ruptured as it does hold boost once desired is achieved...even at a minimal amount of actuator preload of 2mm.
Points to consider:
I found no leaks
