1. Locate your unique access code.
2. Turn ignition key to the ON position. DO NOT START THE ENGINE. The check engine and EPC lights should stay illuminated unless anti-theft is active,
in which case the check engine light will blink continuously.
3. Ensure that the cruise control slider button (this is the upper cruise control button) is in the ON position. If the cruise was ON, turn it OFF and back ON
again.
4. Enter the fi rst digit of your unique access code by pressing the SET button on the cruise control stalk the same number of times corresponding with the fi rst
digit of your security code (ex. for a 9, press the SET button nine times). You do not have to hold the set button for any specifi c period of time, just press the
button and release it.
5. Using the upper switch on the cruise control stalk, turn the cruise OFF to register each digit of your unique access code. Once the cruise is in the OFF position,
turn the cruise control back to the ON position and proceed with the next digit.
6. Enter subsequent digits in your access code by following the same procedure you used above, pressing the SET button the number of times corresponding
with each digit. Do not forget to register each digit by sliding the upper cruise control switch to the OFF position. Also, ensure that the cruise control slider
button is turned back ON before proceeding with the next digit. If you make a mistake entering your access code, turn the cruise OFF and then start over at step
two of these instructions. It is not necessary to turn the ignition off and back on if you make a mistake.
7. After you have correctly entered your unique access code and the cancel button is pressed after the last digit, the check engine and EPC lights will start
blinking alternately to signify that the code was entered correctly. If unlocking DirectPort trial software, wait 10 seconds after the lights stop fl ashing before
performing any other EMCS functions.
