Updated with new price and info!!!
UP FOR SALE: (1) ARC Audio KS 900.6...retail for $759.00
spec from Arc Audio's website:
* Advanced microprocessor control system
* Class A/B switching design
* Code based flashing diagnostics
* Designed By Robert Zeff
* Protection against: Reverse voltage, Over Voltage, Speaker Short, and Thermal Overload
* Can drive highly reactive loads
* Hi/Low Level differential inputs for flexible aftermarket/OEM integration applications
* Optically isolated Mosfet power supply
* 2/4/5-6 channel input options and source selection switch
* Block style terminations
* Sub + Sub Bridged on channel 5+6 (Full Range and Low Pass only)
SPECIFICATIONS
Power Output RMS @ 2 ohms 4 x 100
Power Output RMS @4 ohms 4 x 60 watts
THD .01% @ 4ohms
Frequency Response 20Hz - 20KHz
S/N Ratio 77dB
Power output RMS @ 4 ohms (sub channels only) 155 x 2 watts
Power output bridged @ 4 ohms 120 x 2 watts
Power output bridged @4 ohms (sub channels only) 550 x 1 watts
Bass Boost +15dB @ 45Hz
Crossover Butterworth 55Hz - 5.5KHz Variable 12 dB
Fuse 4 x 25 amp
Pic of actual item:
$535 shipped
UP FOR SALE: (1) ARC Audio KS 300.4....Retail for $449.00
Just found out from a local installer that this amp will fit under Mk5's passenger seat
spec from ARC Audio's website:
* Non digital class H switching design
* Hi/Low Level balanced switchblade RCA inputs for flexible integration into most applications
* Quiet Internal Fan cooling
SPECIFICATIONS
Power output RMS @ 4 ohms (bridged) 350 x 2 watts
THD .02%
Fuse 3 x 30 Amp
Power output RMS @ 4 ohms 90 x 4 watts
Power output RMS @ 2 ohms 175 x 4 watts
S/N Ratio 95dB
Bass Boost +18dB@45Hz
Pic of actual item:
$285 Shipped
UP FOR SALE: Hybrid Audio Imagine I61-2 component and coaxial system....Retail for $219
Spec from Hybrid Audio's Website:
**please note, the following parameters are for the midbass drivers only**
Parameter 6 ½” Midbass
Overall Diameter 6 1/2” (165 mm)
Mounting Depth 2 11/16” (69 mm)
Mounting Hole 5 3/4” (146 mm)
Recommended Minimum Crossover Frequency 65 Hz
Pnom Rated Power Input (No Crossover) 50 watts (AES Standard)
Pnom Rated Power Input (No Crossover) 100 watts (AES Standard)
Pmax (With Recommended Minimum Crossover) 175 watts
Frequency Range 55 – 9,000 Hz +/- 4.5 dB
Sensitivity 92.6 dB at 2.83 V/1meter
Mms 9.159 g
Cms 741.33 μM/N
BL 4.606 T*m
Voice Coil Diameter 25 mm (1-inch)
Impedance 4 Ω
DC Resistance 3.9 Ω
Fs 61 Hz
Qms 4.044
Qes 0.651
Qts 0.561
Xmax 12 mm (two way)
Vas 17.43 L
Sd 12.86 mM2
Pic of actual item
$125.00 shipped (SOLD)
All Items are NIB...SOLD AS IS
SPECIFICATIONS
THD .01% @ 4ohms
S/N Ratio 77dB
Fuse 4 x 25 amp
Pic of actual item:
$535 shipped
SPECIFICATIONS
THD .02%
Fuse 3 x 30 Amp
S/N Ratio 95dB
Pic of actual item:
$285 Shipped
Mms 9.159 g
Cms 741.33 μM/N
BL 4.606 T*m
Impedance 4 Ω
DC Resistance 3.9 Ω
Fs 61 Hz
Qms 4.044
Qes 0.651
Qts 0.561
Vas 17.43 L
Sd 12.86 mM2
Pic of actual item
