I ve got a 2004 MK5 golf TDI 2.0 and when I bought it a while ago the small fan was not working at all; Large fan was working almost constantly at full speed and AC was fine.
A couple of days ago I tried to operate the A/C and it wont blow cold air at all, however if turned to hot it works fine. I also realised that the big fan is not working anymore! So none of the fans will go on if the engine is warm or if you turn on the ac.
I did an auto scan through Vag Com but didnt get any faults, I then tested the Cooling fan 1 output and it worked; the fan started spinning like normal, so I guess the fan motor itself is working. Another thing worth mentioning is that the Temperature gauge hasnt gone above 90 degrees even after driving for more than an hour on motorway or minor traffic jam.
I dont want to take my car to stealers which will ask me to leave it with them and charge me silly money. I d rather try some things DIY and replace the part myself if possible or just go to some garage with a problem.
To summarize:
-Small fan is not working at all; Havent tried to measure voltage to it.
-Large fan is not kicking in at all; Was tested through vagcom for operability and worked fine
-A/C not blowing any cold air at all, when turned to hot it blows hot fine; Refrigerant pressure meassured with vagcom ~5.2 bar.
I dont mind fixing the AC at this point, Im more concerned about not frying the engine.
Any input would be highly appreciated! :bow:
To summarize:
