so technically if i get a block off plate for the ko3 wastegate, i can run a external wastegate. so which block off plate can i use in conjunction with our turbo.
There would be more to it than that, Yes you would have to figure out a way to shut the internal gate, either weld it or a solid connecting rod, then you would have to fabricate or purchase a wastegate flange (38mm or 44mm)
Then you have to remove your turbo form the engine, separate the manifold from the rest of the turbo.
Then you have to drill, machine and/or port a hole on manifold.
After that you would have to clean the cast and weld the wastegate flange onto the manifold. (which isn't an easy task to weld cast).
Then you can assemble everything, fine tune the cracking pressure to the software's liking.....but all for what, I think our internal wastegate’s port flows enough without any effect to backpressure or boost creep, if you curious it would be easier to just yank the turbo off the motor and port the waste gate port itself to 28mm.
