Today, I was able to get this part installed without pulling the intake manifold, or the throttle body. I'm not going to tell you it was a piece of cake, because it wasn't. It was a PITA. But, I think I can put enough tips together to make it less painful for anyone else wanting to install this part. My rebuilt HPFP will be in later this week, and I will use that opportunity to take several key photos to put this together. I'll also list the parts needed, and a few helpful tips. Stay tuned! :thumbsup:
Draft Information
RS4 Valve Part #: 079130757
Disclaimer: I assume absolutely no risk for any injury or damaged caused by following this DIY. Always use all safety precautions and common sense to make sure you do not damage anything or hurt yourself. You have been warned.
Draft Information
- Bleed off HPFP pressure using bleed valve
- Remove HPFP line on the right
- Remove T30 Torx on front bottom right
- Release fuel line clamp
- Loosen T30 Torx for the fuel lines on top of the manifold
- Use 14mm crow foot to remove fuel line from OEM FPV
- Use 17mm crow foot to remove the FPV
- Use leverage with wrench at front of intake manifold to pull fuel line from FPV so it can be removed
- Thread RS4 FPV into fuel rail
- Tighten with 17mm crow foot
- Tighten fuel line to FPV using 14mm crow foot
- Tighten fuel line on HPFP
- Tighten 3 fuel line T30 on the intake manifold
- Turn ignition to accessory to prime fuel rail and inspect for any fuel leakage. Tighten anything as required.
- Start and let idle. Again check for any fuel leakage or any other issues
- Enjoy your upgrade!
