I had the same thing, pegged duty cycle boost was not hitting requested at all with B7 on my software. Now B8 or B9 I can hit without the duty cycle pegged. Even if the new actuator is different from oem spec duty cycle the car is adapting and it shows that I can reach these requested values.
7-5-7 OEM actuator
8-6-7 Forge Actuator
Red=Actual Blue=Requested
Not to mention 18* BTDC =)
Thats holding 13-12.47PSI from 6k to 6600rpms while still advancing!
I just changed my settings last night and everytime I do the adaptation process starts over so I just took these morning so maybe 5 miles of adaptation period, N75 will undoubtly lessen
This is with B9 and a week of adaptation time
I hate to keep pushing it but I was having the same problem and the only change I made from then was software advancements and the new wastegate actuator
And from my previous claims as you can see with the OEM actuator I was making 220ish G/S Peak
Now I'm just sustaining that peak number earlier.
Take it as you may my settings are way more agressive then what apr requests so if putting more stress on your turbo is your worry from the way Little red fasts logs look he is just hitting what APR requests only but this modification does give you the ability to go above and beyond that at your own mercy =P
