I’ve spent about a months time back and forth in my spare time trying to fix a boost/vacuum leak kind of symptom in my car. This problem has been ongoing for a long time now, probably half a year now.
Car: GTI FSI 06 DSG
Added hardware:
• APR Stage II + (with all hardware required)
• Intake Forge Twintake
• Rev D Diverter valve
• BSH Front PCV Revamp
I’ve recently pressurized the turbo inlet (blocking the PCV rear breather hose to valve cover, oil cap off) with 20 PSI. No boost leak found from turbo outlet all the way to intake manifold. I used windex spray to find the leaks whilst the system was under pressure.
I inspected my DV once again, and it looked fine.
I don’t have VAGCOM so I can’t properly diagnose my car and find out the problems in detail.
I was hoping someone with experience or ideas could point me in the right direction before I have to spend more $ such as investing on the VAGCOM cable.
I’ve used TORQUE (Android application + OBDII reader) to log my boost (lol). I’ve attached it below:
I also logged my friend’s car, S2+ FSI GTI to see if application/reader was not reliable, but his logs came out good.
Any tips on what I should inspect next would be helpful.
Notes:
Picture 1 = Log of a pull in 2nd gear.
Picture 2 = Besides the one pull in the graph (where it peaks at 21 psi), I drove around as gentle as possible avoiding using the turbo.
Car: GTI FSI 06 DSG
Added hardware:
Notes:
