Bargain retrofits for golf mk5 = supply&fit or fitting only
Rate my VW retrofits out of 5!
  • Total voters
    34
hkp
Kinda like a V-dubya..
East Anglia
You should start selling those lights on eBay bud, you'd make a killing! I am tempted, but so many other thinks to do!
omeydz
BARGAIN RETROFITS!*PM ME*
S.E. London
Golf MK5 1.4
Asmed's 2007 07 Passat Estate 2.0 TDI DSG 170 SEL.
Work: Multifunction steering with DSG paddleshift and deactivate seatbelt warning.
(Forgot to take the wrapping off the steering wheel!)
omeydz
S.E. London
Golf MK5 1.4
Matt's 2008 58 Golf Match TDI 5speed manual Bluemotion DPF
Work: RNS510 Navigation System
omeydz
S.E. London
Golf MK5 1.4
Denis' 2007 Irish registered Golf Match TDI 5speed manual
Work: Bluetooth system with voice activation on multifunctional steering.
omeydz
S.E. London
Golf MK5 1.4
Rob's 2006 06 Golf GTI Manual 6 Speed
Work: RNS510 bluetooth, updated maps with full postcode search, Cruise control
omeydz
S.E. London
Golf MK5 1.4
Auto Polar MFA+ FIS+ for red highline displays.
Shows info like boost pressure, fuel litres, coolant/oil/intake/external temp, battery voltage, rpm, speed readouts.
omeydz
S.E. London
Golf MK5 1.4
Paul's 2007 07 reg Golf MK5 GT TDI 170PS Manual 6speed
Work: Cruise control
omeydz
S.E. London
Golf MK5 1.4
Paul's 2008 08 Caddy Maxi 2.0 TDI 140BHP 6 speed.
Work: Multifunctional steering, Cruise control, Coding mods, supplied midline cluster.
omeydz
S.E. London
Golf MK5 1.4
Jerry's 2008 '58' Golf R32 Manual.
Work: MDI Kit (In-dash) for RNS510.
Later: OEM LED tail-lights, Cruise, Highline cluster, Multifunctional steering.
Kippers_Cracks
Worcs
hi,
i have a 2.0 tdi GT and want a full xenon conversion to ensure i stay on the right side of the law
new headlamps
fitting of washerjets
fitting of axle sensors
could you do this ?
please advise how much if so ?
supply and fit or fit only
thanks
omeydz
S.E. London
Golf MK5 1.4
Martin's 2008 '58 Golf GT TDI 170 manual.
Work: Cruise control and GTI flat bottom MFSW and selection of coding mods incl alarm chirp and seatbelt warning off.
Kippers_Cracks
Worcs
PM sent.
Thanks
hi,
thanks for the offer of supply and fit used r32 xenon headlamps but you must be unaware of the new mot regulations from january 2012 ?
After market hid (xenon) headlights must have headlamp washers and axle sensors fitted for them to pass
1.7 Headlamps 1.7 - page 1
Information
Method of Inspection
Reason for Rejection
1.
Check the presence, security and operation of the headlamp switch.
2.
Where HID or LED dipped beam headlamps are fitted, switch on the headlamps and check the operation of any headlamp levelling and cleaning devices fitted.
3.
Check that the vehicle is securely fitted with obligatory headlamps, as follows:
a matched pair of main beam headlamps, and
a matched pair of dipped-beam headlamps
Note: Main and dipped-beam functions may be provided by a single pair of headlamps.
1.
A switch missing, insecure or faulty.
2.
A headlamp levelling or cleaning device inoperative or otherwise obviously defective.
3.
A missing, insecure or obviously incorrectly positioned obligatory headlamp.
Note: Class 3 vehicles may require only one headlamp (see Section 9.1).
Note: The precise position of headlamps is not part of the inspection, but check visually that the lamps are at about the same height and the same distance from each side of the vehicle.
This inspection applies to all obligatory headlamps fitted.
Headlamps are not required to be fitted to vehicles used only during the hours of daylight, which are fitted with neither front nor rear position lamps, etc. (See 1.1.A).
Vehicles equipped with High Intensity Discharge (HID) or LED dipped beam headlamps may be fitted with headlamp washers and a suspension or headlamp self levelling system.
Where such systems are fitted, they must work; however, it is accepted that it may not be possible to readily determine the functioning of self levelling systems. In such cases, the benefit of the doubt must be given.
Headlamp washers may work in conjunction with the windscreen washers (when the dipped beam headlamps are switched on) or by a separate switch.
HID lamps may be identified by:
taking a few seconds to reach full intensity
having a bluish tinge to the light
having an igniter module/inverter behind the headlamp
having ‘DCR’ marked on the headlamp lens.
HID headlamps use high voltage and extra care should be taken when inspecting these items.
4.
With the headlamps on, switch between dipped and main beams checking that:
a.
each headlamp illuminates immediately it is switched to either dipped or main beam
b.
either:
all main beams are switched off by one switch (dip switch) leaving a matched pair of dipped-beams switched on, or
the main beam headlamp reflectors are deflected by a driver’s control, to make them dipped beams
c.
on vehicles first used on or after 1 April 1986, the ‘tell-tale’ illuminates when main beam is selected.
4.
a.
A headlamp does not operate immediately when selected on dipped or on main beam
b.
operation of the dip switch does not:
extinguish all main beam headlamps, and leave on at least one pair of dipped-beam headlamps, or
deflect the main beams to make them dipped beams.
c.
the ‘tell-tale’ does not illuminate when main beam is selected.
Cont’d
Cont’d
Cont’d
The M.O.T. Inspection Manual Issue Date 01 January 2012
omeydz
S.E. London
Golf MK5 1.4
It says that self levelling/washers may be fitted (not MUST), and if it is fitted, then it MUST be working. Washers arent fitted and nor are the self levelling therefore should pass fine.
omeydz
S.E. London
Golf MK5 1.4
Paul's 2007 '07 Jetta 1.9 TDI SE DSG 6 Speed
Work: Cruise control and Scirocco Multifunctional steering with DSG paddleshift.
