1) Wait, another K04? Was it shaft play or something else?
2) I have been trying to figure out how to get the car to pull more at the higher revs. As you know, the K04 torque curve is still really peaky. It just feels like it pulls strong up through the midrange and then nothing.
3) I am questioning a few things, like whether I should go back to a stock PCV instead of the catch can, and it’s worthwhile to swap the BSH throttle body pipe back in (running the OEM pipe right now because the BSH fitted poorly before).
1) It was blowing a bit of smoke. Shaft play, once the turbo was removed there seemed to be minimal movement(???). But I plan on having it rebuilt (maybe)...because I bought the new K04 from FCP Euro, so it has a lifetime warranty so long as they are in business.
2) Only way to get high-end power is to re-tune it and swap some torque for HP. A custom tuner should be able to do so. You can try a United Motorsport dealer or see if you have a local custom VAG tuner.
3) My recommendation, regarding the 'PCV vs delete' is always; a) Leave the PCV when you are daily driving it, and it isn't yet a race car. Solely for the benefit of crankcase vacuum when driving in vacuum.
b) Go on and delete the PCV when you have assigned it to track use only, because you are driving it mostly in boost and it would have no benefit from vacuum; for not being driven in vacuum. When boost is present, the vacuum source is shut-off to the crankcase.
You can see, using pause, both take ten seconds to reach 100. The difference comes from 100 to 120. Obviously this isn't 100% accurate, but I know the DM never beat the GIAC in the 1/4 mile.
This is my GIAC tune:
This is my DM tune:
