GoatAutomotive
- Georgetown, TX
- 2017 VW GTI SE, DSG
I need your help, gents. Mostly good, but some unplanned “bad” that’s got me pretty upset and disappointed.
I finally purchased and installed the last of the missing ingredients for my chassis setup on the Stormtrooper: Bilstein B8 dampers.
Their road and track manners are, for what I was after, truly awesome. The car feels like a BMW M3 with wrong-wheel drive (FWD), with a firm refinement that never lets the car or tires get out of sorts. The car has almost zero pitch, roll or squat now. Chuck it into a corner. It gives zero f***s.
Leave a light aggressively in first. It now digs and claws into the pavement, as the car no longer lifts the front end when launching. I honestly thought I would need pricey coilovers and stiff spring rates to reach this summit of suspension greatness.
So all is right in the world, right?
Unfortunately, not quite. And this is where I need the wisdom and experience of other current/former B8 owners:
The front B8s are doing what many others have reported: bottoming out and smacking on big dips and hard bumps/impacts.
This began in the first ~15-20 miles following installation. Any harsh drops in pavement surface, or sudden rises/impacts when you’re driving above ~30-35mph, and they crash like a musician on a bender.
It’s a horrible sound and sensation, not becoming on any German vehicle:
Think Holly Holmes giving someone an uppercut and hearing the skull disconnect from the vertebrae:
POP! BANG! [insert vintage Batman comics here]
For clarity, I am running the H&R OE Sport springs. These did extremely well with the stock dampers on the car, and ZERO trimming of the OE bumpstops at that time.
H&R advertises a 0.75” drop (20mm). As others have cited, final drop (after settling) is closer to 1” all around, and that is utilizing the Audi TT rear pads for leveling. Look at the pics and it’s identical to the VWR or Eibach drop, but with a progressive spring.
I’ve observed lots of folks running the VWR and ED springs, which have very soft spring rates, excessive drops, or both – and they encountered this bottoming out issue on the B8s. I thought I would be immune with the superior H&R springs and the reduced drop, hence this post.
The crash event is exclusively from the front of the car, which checks out, because I trimmed a modest ~20mm from my rear bumpstops, but the front B8s have internal travel limiters inside the strut body itself.
I did some research to see what was needed to modify the front bumpstops, and it’s wretched:
You have to take the entire strut back apart from the car, mounts, springs, etc…disassemble it on a bench/vice, and separate the entire monotube (chrome strut body) from the yellow steel casing.
Helpful, short videos here of this being done:
I went through hell to get all four corners done in time for my recent track event on 5/10 (along with redoing all the brakes, flushing the fluid, etc). Consequently, the thought of doing any more suspension work on the car this month is pretty nauseating. Just being honest.
More than anything, I just wanna drive and enjoy the fruit of my efforts & research.
Background established, my question to all you fine folks:
Has anyone here trimmed/modified the B8 internal bumpstops on their car, and with what success?
Videos above of the B8 anatomy and disassembly; pictures of Storm's ride height below. Begin discussing amongst yourselves.
I am about to email Bilstein N/A to get their input.
Thank you in advance, fellas.
