Hi
I'm getting a strange issue with my custom tune and was wondering if someone might help get to the bottom of this.
This issue comes and goes, car will run perfectly one day and then run badly on the next day.
At the beginning I thought it was my Neuspeed induction kit and when I removed it everything seemed to be O.K but then it started happening again.
If you look at the lambda regulation where it's marked in red you will see the ECU adds 25%+ fuel at some point but for no apparent reason.
this only happens in 5K+ Revs.
My setup is:
- Stock K03 Turbo
- Labonte Motorsport WM Injection stage 1, MAP based set to go off at 0.8 Bar
- Stock HPFP
- 3" downpipe with no cat converter
here are 2 log outputs, one is perfect and the other is bad:
Perfect:
BAD:
Did anyone ever notice a similar issue?
Pelase help.
Thanks.
My setup is:
- Stock K03 Turbo
- Stock HPFP
Perfect:
BAD:
Pelase help.
Thanks.
