well, i got my dsg reset and still having the same issue. car is shifting fine at light throttle, in tiptronic, and at 100% throttle. Everything in-between is killer...almost makes me not want to drive anymore!
I just had my Revo REP perform the procedure recommended by George from REVO and OH MY GOD my car SHIFTS SO SMOOTH NOW!!! in every gear it is silky smooth.....!!! so I recommend anyone who has been flashed get this procedure DONE immediately!!! the car feels so much better to DRIVE!!!!!
YAY!!!!:happyanim:
has anyone noticed a difference after having a DSG service (Fluid and filter change)?
heard problems of software due to stock dv
I also asked my dealer to replace my DV with the NEW UPDATED no Diaphram one..and he said if the throttle body cleaning doesn't work, then he would try that..and if that doesn't work...then we are going to go for a NEW mechatronics......my appt. is thursday 3/19, so I will see.
Anyone else drive your car regularly? I think the DSG is adaptive, and it may be having trouble adapting to 2 different driving styles.
the TCM is a totally seperate module from the ECU. They have seperate programming. UNless they are also reflashing the TCM I don't see how they can do anything for the transmission.I understand what you guys are saying. However, APR and Unitronic have both addressed this issue. If you read previous posts, APR has made the connection between the ecu being reflashed and the need to adjust the tcm. They also had similar problems with shifting and addressed it in their latest reflash. If you read the previous posts by Revo (page 2 and 4), they are saying that they did not adjust anything other then the ecu, and also claim that their is no connection between the ecu and shifting (page 4)...also this is not a matter of the car being cold vs. warmed up. You can notice that in a stock GTI, and after driving for three hours, I can still produce the problem at half throttle. Yes, I'm sure it is a problem with the added power, but other companies have addressed the issue. It sucks driving my car and only putting 30% throttle down instead of normally being able to put 50% and having to fiddle my way around.
