I'm still new to the list, so this is probably a dumb question that everyone knows how to do but me ....
Today I replaced the ABS Pump / Controller in my 2009 GTI (6spd). Started by scanning the entire car (almost every system had a fault of some kind), and resetting every fault that I could. Got it down to only 4 or 5 systems with problems. Copied the ABS long code, replaced the pump, and re-entered long code into to replacement pump - which was successfully accepted after appending two extra zeros (It's a 2011 pump going into a 2009 GTI, but with similar part numbers). At his point I still have various dash light faults for ABS, Traction, and Brake.
So far have bled the brake system twice (AllData says might have to do it 5 times) and have a "reasonable" pedal. Also have run the Brake system test which exercises the ABS Pump at each wheel, with and without pedal pressure, per the diagnostic instructions. Seems to run through the sequence OK.
My problem (at least the most obvious one) is that I can't get the long coding for ABS Module to "stick". Re-entered it 5 or more times, each time it is "accepted" and seems to remain through several tests, fault resets, etc. But then (maybe after cycling the car's power, or other random actions) I take a look back at the Code section and find that it has reset back to all ZEROS.
Note - At this point the car is still up on stands and has not been driven.
So my question: How do I get the ABS Pump / Controller long code to "stick" and not reset itself to all ZERO's??? Must be some trick designed to screw with new guys!
Thanks ..... Fred
Thanks ..... Fred
