Old 04-15-2013, 05:51 PM   #1
Swiper
Formula 5000 Driver
Swiper's Avatar
Drives: MkV Jetta GLI | MkIV .:R32
Swiper's GLI | Build/Photo Thread
***FAIR WARNING! Cellphone pic intensive due to me not having a legit camera. However there are some nice shots here every once in a while***
So figured I'd post a build thread finally. I used to have a 2009 United Grey GTI, was on Koni coils and was Stage 2 and R32 rear end, but I got really sick of two doors and wanted a 4 door GTI, but my buddy was selling his GLI..... so I settled for that. Car is a 2009 Jetta GLI with 2.0T (TSI) APR tuned, APR Ko4 turbo, APR intercooler, APR rear sway, APR Carbonio intake, Raceland downpipe to Magnaflow catback. (I don't have any photo's of the install for this stuff because I bought the car from my friend with all of this )
So I started with ST Coils and the car looked like this.
Then I hated the plastic paddles, so i bought these from S2T Performance
Then ran into a small delay with the downpipe haha, Luckily my buddy hooked it up with some solid welding
Then this happened....
So started with these materials....
-New version of Airlift Performance front struts/bags. Camber plates up top. I believe I have 2 and 5/16" of threads.
-Airlift double bellow rears
-Bilstein Sports rear Struts
-Accuair E-level and Vu4 version 3.0
-AZ OB2 comp.
-Accuair skinny 5 gal.
-3/8 SMC Water trap (mounted before the manifold)
First thing first was getting the trunk set up the way I wanted it. This is my daily so I can't afford to leave it on jack stands all day. Anyways, pics
So I started with 1/2" MDF and used the old trunk carpet as a template, then made a small cardboard template to make the small indentation to the left (for the compressor to sit) after that I screwed 1" strips of wood underneath so I can run wires/ lines/ etc. the split down the left half of the trunk is so I can access my spare tire by taking out the right side, it is also because that is where my seat splits and I still have the ability to put long packages and such in the trunk/thru seats. You'll see. Wrapped it in the sub box fabric that I got from best buy, it is a really close match and looks good. Used some 3M fabric glue adhesive spray can stuff I got from Walmart. Worked well, had to use a thick coat on the MDF and fabric since they are porous materials, let it tack up a bit, then stick together. Wrapped it around the edged and glued the edges and around the back side and wrapped the fabric a few inches on the other side and cut the excess.
As you can see I mounted everything along the left side, as stated before I didn't want to lose my thru seats storage. Also I like the way it looks. I was worried about weight distribution, but after driving it I don't even notice the extra weight on the left side.
I forgot to take many pictures after this, but I had the Accuair power kit, I mounted the fuse directly onto the battery box, then routed the wire thru the firewall through a grommet behind the brake pedal. Then ran all the wires (purple for the controller dimming, black controller wire, and orange ignition wire) all through the kick panels along the drivers side. The ignition wire (orange) was routed to the #42 fuse of the panel on the outside of the drivers dash (the one you open the door to get to) using an add a circuit, from checkers. The purple was routed into the cigarette lighter. Pull up the shifter and get to the screws for the coin tray, remove coin tray and cut the gray wire to the cigarette lighter, this is the wire for the light ring around it, just splice it in there and put everything back together. Drilled a hole in the coin tray to route the wire to the e-level controller. I believe that covers wiring. Oh, I grounded everything to grounds I found inside the trunk along the left side (remove the carpet to get to them)
If you guys want more pics let me know and I will try to get some, not sure how good of a job explaining I am doing. I'm hoping to help future mkv guys bagging in their home garage.
Used the Exo mount and turned it so the manifold is on the top of the tank and not the side.
Love the raw tank and the exposed lines and wiring. Everything will be cleaned up with some braided wire covers from Jegs and thinking about using copper lines eventually. I tried to build things as simple as possible to have it as trouble free as possible. Still a work in progress and will update as more things come to mind. Hit me up on here if you want clarification on anything!
I didn't take any pics during the suspension install because airlifts directions for the installs are pretty straight forward. The rear bag directions are on point. The fronts could use some updates (pics and stuff). Anyways....
Touchdown... Photo's by my friend Joshua Semenko (IG account is @deuce_coupe)
Shout outs to my awesome friends that pulled long shifts in my garage. Justin and Jesse from Team Foreign Objects, Cris from Ungluck Inc., the rest of my TFO family for support and info, and my awesome girlfriend that supports my big purchases haha. If I forgot anyone I'm sorry, so thankful for the help I received and doing stuff with you and your friends in the garage is super fun (not to mention saving mad $€£¥)
-Swiper
Team 4NOBJTS | BUILD THREAD | @therealswiper | therealswiper.com
Swiper is offline   Reply With Quote
Old 04-15-2013, 05:52 PM   #2
Swiper
Formula 5000 Driver
Swiper's Avatar
Went to my friend Aaron Boost's house, dropping off an already notched hood to get painted and colormatched platinum grey. So ignore the plate holes and notch because they are going away very soon.
Anyways he snapped a few pics while I was there, dude is awesome! He did coverage for Canibeat for the Wekfest Hawaii Show put on by WekSos http://www.canibeat.com/2013/02/wekf...cial-coverage/
Make sure to follow him on Flikr at http://www.flickr.com/photos/aaron_boost/ and on InstaGram @aaron_boost
Next is E-level sensor install....
Old 04-15-2013, 05:52 PM   #3
Swiper
Formula 5000 Driver
Swiper's Avatar
Ok so finally got around to the e-level. Did only the rears today. On the right LCA there are two holes on the back side, and wouldn't you know the e-level sensor mounts right up to it! So I drilled holes in the exact place on the other side. Then drilled a hole above that on the Upper Control Arm (or whatever it's called) for the end of the rod. The way I have it set up is about 2.5" of travel from fully aired up to fully aired out. Used a 3/16" drill bit and the hardware that came with it. Then I routed the wires through a rubber grommet that comes out on the trunk floor (you have to pull the right side trunk liner out a little to gain access. Anyways from the under side of the car you remove the plastic shielding and it reveals this area all the way to the back and passenger side of the car. I tried to get a good pic. Anyways I'm doing this build in a way where I drill the least amount of holes. On to pics.....
It is exactly the same for you guys in the GTI's (Also the same for Mk6 GTI's)
I will try and get to the front's soon, I broke a sensor trying to do it last thursday :(
Old 04-15-2013, 05:57 PM   #4
bhmkv
Auto Body Appraiser
bhmkv's Avatar
Drives: 07 CW GTI 6SPD sold
Nice car.
Tba
bhmkv is offline   Reply With Quote
Old 04-15-2013, 05:57 PM   #5
Swiper
Formula 5000 Driver
Swiper's Avatar
Went on a cruise to North Shore, my friend Alex Tigardoon took a couple nice shots (ignore the photoshop of the shaved bumper, i have a missing rubstrip because it is with my paint guy so he can get a good colormatch)
Dudes flikr is http://www.flickr.com/photos/alextirgardoon/
Old 04-15-2013, 06:34 PM   #6
apollosfury
designeddwk
apollosfury's Avatar
Drives: 2007 VW GTI
well done!
Revo 3 K04, Air Lift w/V2, Eurojet TBE, S3 Injectors, Neuspeed Discharge Pipe, Unitronic DV Relocation, H&R RSB, EuroSport Strut Bar, Neuspeed P-flo, 42dd stealth catch can, BSH throttle body pipe, AWE DV, BFI stg 2 mounts, Spulen Dogbone, Garrett FMIC
my flickr
apollosfury is offline   Reply With Quote
Old 04-15-2013, 06:45 PM   #7
Swiper
Formula 5000 Driver
Swiper's Avatar
Originally Posted by bhmkv View Post
Nice car.
Originally Posted by apollosfury View Post
well done!
thanks!
Old 04-15-2013, 07:05 PM   #8
.:R32D2
Big Brown Truck Driver
.:R32D2's Avatar
Drives: MKV R32
Clean, I like!
“Speed has never killed anyone - suddenly becoming stationary, that's what gets you.” ― Jeremy Clarkson
MKV R32 #2799 Neuspeed P-flo || APR RSC 3" Catback || APR Stage 1 || UM DSG Flash || HPA SHS Coilovers|| 18" VMR V710's
.:R32D2 is offline   Reply With Quote
Old 04-16-2013, 06:12 PM   #9
Swiper
Formula 5000 Driver
Swiper's Avatar
finished e-level today, super pumped! works so well! no more airing up and looking out to check ride height haha
Old 04-16-2013, 06:15 PM   #10
M703
FIA World Rally Car Champion
M703's Avatar
Drives: GTI
so clean! love the trunk setup too! looks badass.
Flickr
Tumblr
M703 is offline   Reply With Quote
Old 04-16-2013, 06:39 PM   #11
Swiper
Formula 5000 Driver
Swiper's Avatar
Thanks :) Your car is an inspiration dude.
Tapatalk because bored.
Old 04-16-2013, 09:46 PM   #12
Swiper
Formula 5000 Driver
Swiper's Avatar
[update]
3, 2, 1. (1 is not aired out, but as low as i can go since i don't have my notch yet)
notched hood should be done by friday! then notched frame in the next two weeks or so. Going to a photo shoot saturday so stay tuned :)
Old 04-16-2013, 09:47 PM   #13
Swiper
Formula 5000 Driver
Swiper's Avatar
[update]
Old 04-16-2013, 10:53 PM   #14
jcurotto23
FIA GT Newbie
jcurotto23's Avatar
Drives: 08 UG GTI
looking good man!
INSTAGRAM: Joeycurotto
jcurotto23 is offline   Reply With Quote
Old 04-17-2013, 08:30 AM   #15
VW_GTI5
Eat Sleep VW
VW_GTI5's Avatar
Drives: RS mkv GTI
Send a message via AIM to VW_GTI5 Send a message via MSN to VW_GTI5
Siiickkk. Makes me want to go with Air so bad.
It's gunna be MAAAAAD!
VW_GTI5 is offline   Reply With Quote
Old 04-17-2013, 09:00 AM   #16
Method82
Touring Car Champion
Method82's Avatar
Drives: 07 MKV DSG Black Magic
Send a message via AIM to Method82 Send a message via Yahoo to Method82
lots of clean cars come out of Hawaii!!
Paul V, Repping the 845/910-919 USA.
Opeth and progressive rock drives me!
07 GTI DSG Black Magic
88 Volvo 740 Turbo intercooled wagon. Beige. :-(
Method82 is offline   Reply With Quote
Old 04-17-2013, 04:33 PM   #17
Swiper
Formula 5000 Driver
Swiper's Avatar
Originally Posted by jcurotto23 View Post
looking good man!
Thanks!
And yeah there are, the car scene here is huge even though the island is very small. We have Wekfest, Stance Nation, Slammed Society, Hellaflush all come out and host shows here.
Old 04-17-2013, 05:14 PM   #18
FaLLeNAn9eL
JESUS HATES FLAT TIRE
FaLLeNAn9eL's Avatar
Drives: black racek0r
I love your car.
Originally Posted by RSMark5 View Post
That car has blown more tranny's than Matt
FaLLeNAn9eL is offline   Reply With Quote
Old 04-20-2013, 05:04 AM   #19
Swiper
Formula 5000 Driver
Swiper's Avatar
thanks :) hood is done gents.
Old 04-20-2013, 05:11 AM   #20
Swiper
Formula 5000 Driver
Swiper's Avatar
slight buildup of paint along the front edge but once the paint hardens it will get wetsanded down, also the ILLEST sticker covers up some big scratch from a key or a bicyclist
Old 04-22-2013, 12:32 AM   #21
Swiper
Formula 5000 Driver
Swiper's Avatar
sneak peak. picture by SantiaGOphotography! Check out all her photos at https://www.facebook.com/santiaGOphotography
Old 09-02-2013, 05:30 PM   #22
Swiper
Formula 5000 Driver
Swiper's Avatar
The rest from that shoot. https://www.facebook.com/santiaGOphotography
In a club called Team Foreign Objects, if you want to follow us check out our instagram @4NOBJTS
