DIY: Amber Singals
darcness
Grand Blanc MI
2008 GTI CW
Preface
Well since I've been doing this for many moons I figured I'd share my knowledge gained with the rest of the community. I've done a full write up on my DIY amber signals and will be adding it to here, with pics and all. Enjoy and have at it if you'd like.
Supplies Needed
1) OEM bulb holders
2) 194 bulb sockets (I get mine off ebay from a michigan seller)
3) Wire strippers
4) Good pair of cutters (preferably flush side cutters)
5) Sharp razor/utility knife
6) Solder iron
7) Solder
8) Vag-Com (or access to one)
Process
The first thing you want to do is obviously start out with your OEM bulb holder. To get to it, you remove the 2 nuts that hold the outer tail sections on and remove the tail and harness. Once the tail is out there are 3 tabs that hold on the OEM bulb holder. Be careful because they are slightly fragile. I usually start with one of the side by side ones, and then do the outer one, then the second side by side. Comes out easy that way.
Here's what you got after the bulb holder is removed...
As you can see it's already set up for a bulb, there's just no bulb holder there nor any wiring per say. The metal tabs certainly go to the center bulb area though, so that makes life easier for us modders.
First step is to remove the bits on the middle section that get in the way. This is where you need a good sharp set of cutters. I like to use side cutters because there's less residual crap to trim away when you're done cutting.
The first cut will consist of removing the side portion of the plastic that's in the way. Cut near the "walls" and it will pop right off. If you look at the first picture, you'll see the bit I'm talking about compared to it being removed in the pic below.
After that part is gone, the second cut consists of cutting away the small "fins" on the sides. Again, cut close to the wall and they should pop off pretty easily. There's a total of 4 of these fins, 2 on each side. Here's how it looks when that's done.
Last cut is to remove the remaining bits inside of the bulb holder area that are on the side walls. There are bits on both sides so make sure to cut them both. These are a bit tricky as they are thick plastic, but again, close to the wall and small bits at time should get them out nicely. Here's the result.
Now take your razor or utility knife and carefully remove any remaining plastic that is left behind. Basically you just want the two "walls" left behind without anything protruding and causing the bulb holder not to fit.
The bulb holders I use I get off Ebay from a seller here in Michigan. They will fit any type of standard wedge bulb. I use Sylvania 921NA LL bulbs. Lots of light output and long life is good. Here's the bulb holders I use and how I receive them.
If you notice, there is a small nubbin on the bottom of the bulb holder. Use your razor knife or cutters to get rid of that. Just be careful not to cut the wires.
After the bulb holder is ready, test fit it into the center portion of the bulb holder. Not any fitment issues and trim the area if needed. You want the bulb holder to sit almost flush with the bottom of the holder assembly.
After you have a good fit, you'll want to trim the wires down so they aren't overhaning the metal tabs as that's were we will be soldering the wires to. The following is an illustration of what I'm speaking of.
Once the wires are cut, put the bulb holder aside and keep the left over green wire, as you'll use this later. Next step is to bridge the two metal tabs together. Basically what we're doing in this step is taking the pins that would normally be bridged externally, and doing it internally. This will tie the blinker signal to the amber bulb. Note the orientation of the tabs and bulb holder, make sure you solder the right ones together. You're soldering the single tab coming from the middle riser to the tab next to it. Here's an illustration.
Once the pins are soldered, then we can cut the old routing to the original bulb. This bulb will now function with the other OEM bulb, making them act as one unit as opposed to two. You don't need to cut much, just enough to break the connection. Just make sure to cut AFTER the bridge. Here's how I do mine.
Now we can add the jumper wire for the two OEM bulbs. I use the left over green wire that was cut earlier from the new bulb socket. Solder this wire from the metal tab on the first OEM bulb, to the second OEM bulb. Make sure you solder after the cut you made above, or you'll have all 3 bulbs on one circuit. Here's how I do mine.
Finally, you're ready to add in the bulb socket. Take the trimmed bulb socket, and put it in the OEM assembly center bit again. Solder the two wires coming from the bulb socket (green and black in this case) to the two metal tabs on the plastic risers. It should look like this when you're done.
Now pat yourself on the back for a job well done, but don't think you're out of the woods yet. Next step is to test it. Go plug your bulb holder assembly back into your tail harness and turn on the hazards. Make sure they blink correctly. Next, turn on your running lights and make sure they work as well. Don't be alarmed if the amber bulb comes on dimly when your lights are on, as we still have to Vag-Com them to make them work right. If all is well, you're good to go and just need to finish up with the coding. If something isn't right, check all your connections, wires, and solder points and make sure nothing is shorted or disconnected.
Once you've got everything working, you can go ahead with the Vag code. Here's what you need to do for that...
Go into Module 09 (Central Electronics) and take a look at your long coding.
It might look something like this:
14 01 8E 23 40 04 15 00 00 14 00 00 00 14 00 00 00 28 77 0B 5C
We care about the segment that looks like this 14 00 00 00 14
Change the second 14 to 00 so it looks like this: 14 00 00 00 00
Basically change byte 14 from 14 to 00.
By doing this coding you're telling the car's controller that you have Euro spec tails installed. What it does is turn off the running light portion of your second "pin" on your bulb holder. This means that the amber light ONLY comes on when your blinkers are on, and no other time. The brake lights still function as dual roles, both as running lights and brake lights. The way it works now, you'll have full outer circle running lights in red, full outer circle brake lights in bright red, and small inner circle ambers for blinkers.
Conclusion
I've done some 20-25 sets of these bulb holders myself and have improved upon the process throughout that time. This DIY uses my latest and most effective/clean way to do this. The good thing about doing the modding internally is that you don't have to splice any of your wiring or mess with the harness. Plus the way I did this, by adding a bulb holder, means you can always change out a burned out bulb easily. Hopefully this helps some folks who want to try a relatively simple DIY that makes a pretty neat difference.
:thumbsup::thumbsup::thumbsup:
Media! \
Zanxrex
New, yet old
USA
2006 MK5 GTI
Very good write up. I used a similar method to yours... except I had the correct OEM euro pieces and use the H6W bulbs VW required. This should work every bit as good as OE when done correctly.
Well done!
BDA MKV
El Paso, TX
2008 Volkswagen GTI
great writeup!
Sorry if this is a thread jack, but if I have Hellas euro leds, the internal wiring is not needed and its just a vag com that is needed, correct? To enter the same coding?...
hobbes
San Ramon, CA
Nice write-up! :thumbsup:
But you forgot to add how you held the bulb socket down onto the bulb holder. I'm guessing with epoxy or some other type of glue?
darcness
Grand Blanc MI
2008 GTI CW
Nope, originally I used silicone but soon after realized it's not needed. Just the wires being soldered in hold it in place. Plus it fits pretty snug in that socket deal once you get all the bits out of the way. I've had mine without it being secured down for about 4 months no and not one problem yet.
orange1218
Chicago-land
Just completed this mod exactly as described by darcness...so far it looks good. I found that having a Dremel made this much easier than using clippers/utility knife. It has not thrown a "bulb out" warning, which is something I was worried about. I took a quick video, but the lighting and resolution is crap...I'll take a better one soon.
(Not sure how to embed videos)
http://www.youtube.com/watch?v=MJTf8rBt9H4
