Old 12-13-2009, 07:20 AM   #1
Darkside
Darkside's Avatar
Drives: Golf V
Lightbulb Better(?) Hatch Pop DIY
I read the threads about how you make your hatch pop by itself and thought I'd share how I did it.
I found that most of the time, the springs either don't push your hatch up far enough or they tend to distort the metal of the hatch over time. My way works fine, doesn't put your hatch at risk and uses only OEM parts. The only disadvantage is that it's more expensive.
Pics in this post aren't mine (I did the install in a dark garage which makes for really bad pics) - they are courtesy of StraightShooter.
Parts
First you need to get some OEM parts from your local dealer:
  1. 2 x 6Y0 827 550 C (Skoda Fabia gas springs) ~40 $
  2. 2 x 1K8 827 761 C (Scirocco bumpers) ~4 $ (can be ordered at VW dealership)
  3. 2 x 1J6 827 439 A (Seat Leon ball pins) ~1.20 $ (can be ordered at VW dealership)
I'm not sure about the $ prices. I paid € 64,- for all of it, that would be like $ 90,-
You can order the Skoda gas springs on ecs-tuning starting January 1st 2010 - thanks to patrick_irwin.
Coding
Geht someone with a Vag-Com and make the following adjustment:
46 - Central Convenience
Byte 2, Bit 3 needs to be checked.
Note that the newest VCDS might not work. Someone at Ross-Tech had the checkbox for bit 3 removed because they didn't think it was used. Get a 704.1 VagCom.
Once the adjustment is done, you can hit the hatch button on the key fob and the hatch should pop. Now, without the new parts, the hatch doesn't get past the release of the lock. This is about to change...
Removing the old parts
First, you're going to remove all the old parts. It's helpful if you have a friend over to hold the hatch for you.
Start with the gas springs. Use a flat-head screwdriver to pry the small metal ring away that holds the gas spring in place. You should be able to pull out the gas spring easily.
Then move on to the ball pins. Get a 13mm (.512 inches) spanner and remove both ball pins. No pics of how to remove them since it's easy enough.
Now remove the bumpers. Get a 24mm spanner and turn the bumper 45 outwards - it should fall out.
Installing the new parts
Start with the ball pins. With your 13mm spanner, screw the ball pins back in. [If you have a touch-up stick in the color of your car, you can paint part of the ball pins (they usually come unpainted).] Apply some grease to the ball pins. Again no pictures. It's easy enough.
Now, install the gas springs. Pry the metal ring away with a flat head screwdriver, install the gas spring and secure it with the metal ring.
Install the Scirocco bumpers. Place them into the hole and secure them with your 24 spanner by turning them 45 clockwise.
Once the Scirocco bumpers are installed, do NOT close your hatch! You WILL damage it!
The Scirocco bumpers are too long and the spring inside is locked. We need to change that before you can close the hatch of your car.
First, you need to release the lock on the spring of the Scirocco bumper. Simply grab the rubber end and turn it 45 counterclockwise until the spring is released:
Now you need to unlock the detent of the Scirocco bumper. Get a 2.5 Inbus (Europe) or a #6 hex key (US) and unlock the detent like this:
Push the bumper in to the last stop and secure the locking mechanism again. Make sure that both bumpers are really pushed in to the last possible stop!
You're done!
You can close your hatch again. If you push the hatch button on the key fob, your hatch should open all the way.
Here's a video of how it looks (and don't tell me my car is dirty - I know. It's got snow and mud and whatnot outside...):
Grab a cold one and:
Darkside is offline   Reply With Quote
Old 12-13-2009, 09:04 AM   #2
mk5gtiguy
Pwaffle Champion
mk5gtiguy's Avatar
Drives: Mk5 GTI Apr tuned
nice write up but i prefer going to autozone and buying what i need for a few bucks then spending god knows what at the dealer... Its just a hatch pop i dont think i need to go all out on top shelf items lol..
Apr Stage 2+, Apr HPFP, ATP Catless Downpipe, 3in Exhaust, performance resinator, Exhaust dump, AFE intake, Koni Sport Full Suspension Kit, Pcv block off Kit, Bsh re route dv kit, vag-com mods, EJ Throttle pipe, EJ Intercooler, AWE vent pod,Joey modded lights,rev D, Neuspeed rear sway bar
mk5gtiguy is offline   Reply With Quote
Old 12-13-2009, 09:13 AM   #3
Darkside
Darkside's Avatar
Drives: Golf V
True.
But personally, I only had problems with the cheap springs so I decided to shell out the 90 $ to do it right.
Besides, I sold the stock stuff on eBay for $45
Old 12-13-2009, 09:56 AM   #4
mk5gtiguy
Pwaffle Champion
mk5gtiguy's Avatar
Originally Posted by Darkside View Post
True.
Ahh nice! cant beat that
Old 12-13-2009, 02:22 PM   #5
Sacha
Drives: Golf V GT
nice
do you got a video of it when it pops open?
Sacha is offline   Reply With Quote
Old 12-13-2009, 02:32 PM   #6
bazzle
Formula 5000 Driver
bazzle's Avatar
Drives: 2008 R32 Golf
Well done.
I tried the sheap spring way and bent my door frame where the strut pins are, removed that idea.
Wondering if all you need are the Scirroco bumpers??
Bazzle
bazzle is offline   Reply With Quote
Old 12-13-2009, 03:34 PM   #7
cosedsc
EE Militia
cosedsc's Avatar
Drives: MK5 GTI
where do I buy EURO parts
cosedsc is offline   Reply With Quote
Old 12-13-2009, 03:47 PM   #8
Darkside
Darkside's Avatar
Drives: Golf V
Originally Posted by Sacha View Post
nice
Going to make one tomorrow.
Originally Posted by bazzle View Post
Well done.
Bazzle
Definitely not. You NEED the skoda dampeners. I tried it without the ball pins (didn't want to paint them) but I'm going to put them back in. If it's too cold outside, the bumpers and gas springs sometimes aren't enough to fully pop the hatch.
I also tried it with just the Scirroco bumpers... it lifts the hatch beyond the release of the lock but not far enough to actually open it. Note that I haven't deadened my hatch. There is no extra weight in it.
So no, you definitely need at least the skoda dampeners and the scirroco bumpers. And if you want to do it right, you need all three parts.
Old 12-13-2009, 04:40 PM   #9
Adv4nc3r_Mk5
VW obsessed
Adv4nc3r_Mk5's Avatar
Drives: VW Golf TDI
not very useful for most of members as they dont have seat/skoda parts in US
but x2 on video, i wanna see the result
"If you want something you've never had, then you've got to do something you have never done"
Adv4nc3r_Mk5 is offline   Reply With Quote
Old 12-13-2009, 04:59 PM   #10
GTIMKV20
APR Stage I
GTIMKV20's Avatar
Drives: '12 GTI CSG DSG
interested in the video as well, I've always been scared to do it the cheap way and bend something that should not bend!
GTIMKV20 is offline   Reply With Quote
Old 12-14-2009, 03:49 AM   #11
Darkside
Darkside's Avatar
Drives: Golf V
I bet there's a company that can get them for you. If not, just ask someone you know in Europe to buy the parts for you.
If some people are interested I'd be willing to get the parts and mail them.
Edited first post and added the video.
Old 12-14-2009, 04:49 AM   #12
Adv4nc3r_Mk5
VW obsessed
Drives: VW Golf TDI
i am from europe so i dont have a problem with that. thnx for the video.
so your solution doesnt need any springs ? just those 3 things and its all set up?
Old 12-14-2009, 04:53 AM   #13
Darkside
Darkside's Avatar
Drives: Golf V
Exactly. No springs, no heatshrink tubing, no messing around. Install those 3 OEM parts and you're set.
Old 12-14-2009, 06:47 AM   #14
BaranE
Rally Car Newbie
Drives: 08 GTI MkV
I just checked with my dealer. Seat part is also a VW part so it can be ordered by the VW dealers. So 2 parts from the VW and 1 part from the Skoda dealer. Also part number 1J6 827 439 has been superseded by 1J6 827 439 A.
BaranE is offline   Reply With Quote
Old 12-14-2009, 07:00 AM   #15
Darkside
Darkside's Avatar
Drives: Golf V
awesome... i'll update the post.
Old 12-14-2009, 07:25 AM   #16
Adv4nc3r_Mk5
VW obsessed
Drives: VW Golf TDI
would love to do that, but i have to fix my hatch door first. when i want to close it i have to use much more power
Old 12-14-2009, 11:45 AM   #17
vwangler
Keep ur $ I <3 my clunker
vwangler's Avatar
Drives: 1983 MKI GTI, BMP 2008 MKV GTI
This is def. better. My springs are worn out, damn things barely pop the hatch now. I suggest that anyone interested in this mod make friends with the guy/girl behind the parts counter. I was able to get wholesale during my last visit, which saved me 40%.
My MK1 Build!
H2O Tuning
SOWO 11
vwangler is offline   Reply With Quote
Old 12-15-2009, 11:48 PM   #18
patrick_irwin
Formula 5000 Champion
patrick_irwin's Avatar
Drives: 67 slammed beetle
ok well no gas skoda shocks, but what part 1K8827761B or 1K8827761C. C is like 90cent more, where can i get those gas shocks in the US?
patrick_irwin is offline   Reply With Quote
Old 12-16-2009, 04:57 AM   #19
Darkside
Darkside's Avatar
Drives: Golf V
C should be the successor of B, nothing more.
Old 12-16-2009, 10:31 AM   #20
patrick_irwin
so im not going to need the gas shocks, im confused. im about to order the ball pin and the B bumpers.
Old 12-16-2009, 10:52 AM   #21
PyRo H4cKeR
PyRo H4cKeR's Avatar
Drives: 10 MK6 GTI 6MT
No you want the shocks.
The ball pin and gas springs you can get at the dealership
Does anyone know if there's any site you can get the gas shocks? Shipped to the us?
PyRo H4cKeR is offline   Reply With Quote
Old 12-16-2009, 10:57 AM   #22
chris32
Out of control
chris32's Avatar
Drives: Black Betty
I'm going to call some dealers in the morning, can't wait to do this.
.:R32
chris32 is offline   Reply With Quote
