Old 12-17-2006, 07:37 PM   #1
edison_GTI
Candy White FTW
Drives: 2006 GTI
Urgent - Door Skin Removal DIY
Hey guys, I need to check the inside of the doors for rattles. For that, I will have to remove the outer door skins. I already removed the door panels, but the rattle originates from somewhere inside the door.
Do you guys have access to a Bentley manual and post how to remove the outer door skin?
Thanks, Edison.
edison_GTI is offline   Reply With Quote
Old 12-17-2006, 08:47 PM   #2
Boonedock82
Formula 5000 Driver
Boonedock82's Avatar
Drives: 2007 BM MKV GTI MT
Holly crap you seriously want to remove the door skin???? Doesn't that involve cutting and welding????? or am I a tard?
07 BMP GTI w/ Huffs, BMC-1208
Bring is ON! http://boonedock82.mybrute.com/
Boonedock82 is offline   Reply With Quote
Old 12-17-2006, 11:06 PM   #3
edison_GTI
Candy White FTW
Drives: 2006 GTI
The door skin is bolted to the door frame. I want to know how to remove the handle. Check it out:
Old 12-18-2006, 02:31 AM   #4
thomaschh
thomaschh's Avatar
Drives: Mk5 GTI
Thanks, Edison.
How to remove door skin:
Drive to dealer and tell them to fix the rattles.
Seriously, don't you think you should let them take care of that. Warranty is your friend.
thomaschh is offline   Reply With Quote
Old 12-18-2006, 08:11 PM   #5
thesaint
Drives: 07 UG 4 DR
here you go
check out vortex
http://forums.vwvortex.com/zerothread?id=2984471
thesaint is offline   Reply With Quote
Old 12-18-2006, 08:18 PM   #6
edison_GTI
Candy White FTW
Drives: 2006 GTI
Originally Posted by thesaint View Post
I wrote that DIY today
Old 07-06-2009, 07:42 AM   #7
Jol-a
Jol-a's Avatar
Drives: Golf TSI DSG
Hi guys!
I need a quick advise!
Here's my problem: How do I take the door handle off?
I'm allready at this point:
http://s221.photobucket.com/albums/d...t=MVI_4420.flv
The handle is moving there normally, but I have no clue how I can remove it from the door. I've screwwed that screw inside and it doesn't let the handle to go off...
Jol-a is offline   Reply With Quote
Old 07-06-2009, 05:25 PM   #8
BamaKID
FIA GT Champion
BamaKID's Avatar
Drives: Tornado Red MkV '08
torx bit from the side
BamaKID is offline   Reply With Quote
Old 07-06-2009, 09:46 PM   #9
Cryptic1911
Formula 5000 Driver
Drives: 08 Candy White GTI 6spd Manual
Send a message via AIM to Cryptic1911
you have to jiggle the handle and pull it towards the back of the car. the front part goes in and has a U section that clips in around a post. it just pops off. just jiggle it around and pull it back, it should come off
Cryptic1911 is offline   Reply With Quote
Old 07-07-2009, 02:27 PM   #10
Jol-a
Jol-a's Avatar
I finally got it off! Thanks guys
First it seemed that it won't come out, but when I got mad, then it gave up
I allready gave some Dynamat treatment for the skin
Old 07-10-2009, 08:37 PM   #11
Rabbid0281
Oval Newbie
Rabbid0281's Avatar
Drives: Amelie
yeah i had to figure out how to do this too. used a diff howto but i still have bullet hole...
Rabbid0281 is offline   Reply With Quote
Old 07-12-2009, 10:13 PM   #12
idk alex
idk alex's Avatar
Drives: Skateboard
bullet hole, damn hardcore
FS: PART OUT
idk alex is offline   Reply With Quote
Old 07-13-2009, 04:29 AM   #13
Rabbid0281
Oval Newbie
Rabbid0281's Avatar
Drives: Amelie
Old 07-13-2009, 04:49 AM   #14
Boonedock82
Formula 5000 Driver
wow!
Old 07-16-2009, 08:36 PM   #15
G-rig
Formula 1 Driver
Drives: MY10 Golf GTI
Just a quick one guys, do the door skins go back into place easily in terms of aligning them? Getting some dynamat today and want a good job with the skins off.
Cheers,
Edit: taking the skin off to apply dynamat seems a bit hardcore, and the audio shop says they can unroll it and get almost the same finish from the inside of the door.
G-rig is offline   Reply With Quote
Old 07-16-2009, 11:35 PM   #16
A41.8QTM
That's what she said
A41.8QTM's Avatar
Drives: 2008 MKV GTI 5dr
Bullshit. Your audio shop has obviously never been inside the door of a MKV. There is no way you can do anything but get a small piece behind the woofer without removing the outside sheet metal. even going through the speaker hole there are the window supports to deal with.
Originally Posted by G-rig View Post
Edit: ...and the audio shop says they can unroll it and get almost the same finish from the inside of the door.
Milltek / APR / DM K04+/ Eurojet / Forge / BSH / Koni / Eibach
Driver Motorsport 304WHP / 325WTQ
A41.8QTM is offline   Reply With Quote
Old 07-16-2009, 11:46 PM   #17
G-rig
Formula 1 Driver
I've told them I want to do it myself, and the pic above is a neat job!
Old 07-17-2009, 12:56 AM   #18
G-rig
Formula 1 Driver
Does anyone here know if Stinger Roadkill is worth the extra 20% in price as apparently it's a bit thicker, but not sure you'd hear a difference??
Look forward to doing my door skins soon!
Old 08-03-2009, 08:59 AM   #19
plac
GTI Master
Drives: 2013 GTI DSG
Originally Posted by A41.8QTM View Post
Did you use those metal clips to hold your woofer adapter? Are they strong enough to get really tight?
Unitronic Stage 2 93 / Unitronic DSG Stage 1 / Unitronic Customized Downpipe / GFB DV+ / Golf R Intercooler / OEM LED Tinted Tails / Tyrolsport Deadset Collar Kits Front + Rear / Soundaktor Switch
160 Video GTI Reference Library
plac is offline   Reply With Quote
Old 08-03-2009, 09:00 AM   #20
plac
GTI Master
Originally Posted by Jol-a View Post
that is hot
Old 08-03-2009, 09:02 AM   #21
plac
GTI Master
I am screwed on my outer door panel removal so far because i have a 4 door. I do not have that big silver sticker on mine which gives access to the secret door handle screw. I heard that the 2 doors have the big sticker covering the opening. I only have 2-3 normal torx bolts and no stickers. Even my Bentley doesnt give me enough info. Anyone know the specific bolt you touch to unclip the *4 door* front door handle?
Old 08-03-2009, 09:21 AM   #22
Maverick
Formula 3000 Champion
Drives: 08 GTI DSG Leather CW
This should help out.
Door Handle and Housing Removing and Installing
http://www.my-gti.com/1138/door-hand...and-installing
website: www.my-gti.com
Maverick is offline   Reply With Quote
Similar Threads
DIY: Short Shifter Install blkmagic2006gti DIY + Maintenance + Tips/Tricks 27 03-18-2017 08:52 AM
DIY stereo removal with pix h82bslo DIY + Maintenance + Tips/Tricks 74 09-07-2012 04:09 AM
DIY - Engine Cover Removal TeknoGroover DIY + Maintenance + Tips/Tricks 10 01-06-2011 08:09 PM
DIY: OEM Diverter Valve 335 Trojan DIY + Maintenance + Tips/Tricks 3 12-05-2006 03:48 AM
