Old 02-12-2019, 10:21 PM   #2399
g60_corrado_91
GolfMkV Elite
g60_corrado_91's Avatar
Drives: 2006 Candy White GTI Pkg 1 6MT
Good to see the build is still going well!
Unitronic Stg 2+ KO4
My flickr
g60_corrado_91 is offline   Reply With Quote
Old 02-15-2019, 11:37 PM   #2400
eurocars
5/17/15 - Never forget
eurocars's Avatar
Drives: GTI
Dual pinned my IE crank pulley because I’m paranoid about shearing the key way
eurocars is offline   Reply With Quote
Old 02-18-2019, 11:22 AM   #2401
bon qui qui
Formula 3000 Driver
bon qui qui's Avatar
Drives: '06 GTI / '17 Taco
Didn't feel like switching to a press fit pulley?
CMP, VIR, AMP, Watkins Glen, Daytona, NCM, Road Atlanta
bon qui qui is online now   Reply With Quote
Old 02-18-2019, 03:30 PM   #2402
eurocars
eurocars's Avatar
Drives: GTI
It is press fit, now also pinned AND has a friction shim. It’s the IE pulley
Old 02-18-2019, 04:37 PM   #2403
bon qui qui
Formula 3000 Driver
Lol, that's perhaps a little overboard. But better safe than sorry! I have the older one (before it was the press fit, billet steel version) and only did the one dowel.
Old 02-21-2019, 09:39 PM   #2404
eurocars
eurocars's Avatar
Drives: GTI
Added 2 more hangars to my catback today, it helped it sit a little bit higher and not flex so much. Also got backed into while in the new daily when picking it up from the welder
Old 02-22-2019, 03:08 AM   #2405
snobrdrdan
former GTI owner
snobrdrdan's Avatar
Drives: no VW
Send a message via AIM to snobrdrdan
Adding a tip to the exhaust?
(if so, what style?)
So, now that it's up & running, you're keeping the Passat?
snobrdrdan is offline   Reply With Quote
Old 02-22-2019, 08:20 AM   #2406
eurocars
eurocars's Avatar
Drives: GTI
Leaving it a single 4” outlet, no fancy tip.
Decided i might as well keep the Passat since i fixed/upgraded all of the common failures. It only has 130k on it while my MK4 has 240k. Going to fix oil leaks on the wife’s X5 then sell the golf
Old 02-22-2019, 09:08 AM   #2407
clockwise33
New York Giants Fanatic
clockwise33's Avatar
Drives: 2006 GTI 6MT Pkg2
How's the vibration in the Passat without the balance shafts?
K04+APR+BillyBoat+Eurojet+Eibach+BBS+IE HPFP+SRE Clutch+JL-W7
clockwise33 is offline   Reply With Quote
Old 02-22-2019, 09:49 AM   #2408
eurocars
eurocars's Avatar
Drives: GTI
Barely noticeable since its on stock mounts. You can tell something is different vs a "normal" FSI but its hardly any worse than my MK4 2.slow
Old 02-22-2019, 01:17 PM   #2409
clockwise33
Very interesting. I wonder how much worse mine would be with 034 street mounts.
Old 02-23-2019, 02:53 AM   #2410
snobrdrdan
former GTI owner
snobrdrdan's Avatar
Drives: no VW
Good plan....are you gonna mod the Passat at all?
Maybe a tune?
What's the interior like btw? Clean?
Old 02-23-2019, 09:09 AM   #2411
eurocars
eurocars's Avatar
Drives: GTI
I’ll atleast put a catless dp on it and tune it, not sure the slush box can handle much more than that. I have a spare 6 speed, so if i come across a good deal on a clutch kit i might swap it but it is kind of nice not having to shift in a daily cruiser.
The interior is in pretty much perfect condition. I’m planning on picking up some monster mats and an android head unit but that’s about it
Old 02-25-2019, 11:27 PM   #2412
eurocars
eurocars's Avatar
Drives: GTI
Engine harness is very close. Need to add plug for aux injectors and loom over the rest of the engine harness but it’s already cut and ready. Figured i should probably test it before sealing it all up. Could technically start the engine now but I’m going to finish all the odds and ends before firing it
Old 02-26-2019, 02:41 AM   #2413
snobrdrdan
former GTI owner
snobrdrdan's Avatar
Drives: no VW
Iíll atleast put a catless dp on it and tune it, not sure the slush box can handle much more than that. I have a spare 6 speed, so if i come across a good deal on a clutch kit i might swap it but it is kind of nice not having to shift in a daily cruiser.
The interior is in pretty much perfect condition. Iím planning on picking up some monster mats and an android head unit but thatís about it
Nice
Are you replacing the (now) broken grille?
It doesn't have the Sport package (seats) does it?
And/or what options does it have?
Old 02-26-2019, 10:26 AM   #2414
eurocars
eurocars's Avatar
Drives: GTI
Originally Posted by snobrdrdan View Post
Nice
Will be replacing it eventually, trying to decide if I want a badgeless grill or stick with OEM. It doesnt have the sport package seats unfortunately or many other options but it does have the cold weather package and sunroof.
Ordered an RCD330 for it lat night, should be here in a few weeks. Hopefully the CAN module doesnt need updated since its an 08. Looking for new shifter trim since mine is peeling like every other VW with the chrome
Old 03-01-2019, 02:25 AM   #2415
snobrdrdan
former GTI owner
snobrdrdan's Avatar
Drives: no VW
Badgeless looks weird on those cars IMO
I know you mentioned the fenders (rust) before, it's not still under corrosion warranty is it?
Or you are you gonna swap them out?
Old 03-01-2019, 08:16 AM   #2416
eurocars
eurocars's Avatar
Drives: GTI
Had a friend at VW that was going to check the corrosion warranty for me, but forgot to follow up with him. If it’s not covered, they’re easy enough to swap out
Old 03-02-2019, 08:20 PM   #2417
eurocars
eurocars's Avatar
Drives: GTI
RCD330 installed in the Passat, works awesome. Might have to pick one up for the GTI
Old 03-04-2019, 11:31 AM   #2418
bon qui qui
Formula 3000 Driver
I had one of those in my Grey GTI and like it a bunch.
