Old 07-23-2007, 02:41 AM   #45
funny
VCDS guru & soon Dad x2 !
funny's Avatar
Drives: Silver DSG MY07 GTI
Light brightness adjustment through VAGCOM
Thread ressurection.
You can add this to your PDF if you want DPham.
You can also adjust the brightness of the DRL (assuming halogens, i have xenons so i can't confirm), front fogs, rear park, rear brake lights as park lights, rear fog as park light.
Refer to DPham's PDF, or easier still just move through the bytes on your VAGCOM under central convenience.
The decimal values are how BRIGHT you want them to be, not how much to dim by (as you would assume by reading the vagcom screen), i.e. 0=off, 100=maximum brightness.
The rear park is the inside (hatch half) of the rear light, the brake is the outer half. Normally set at 20, and you wouldn't want them set at 100, or no one could tell the difference when you brake...
Couldn't seem to get any difference with front park light dimming values.
Anyone used the "backup" function of fogs for front low beams? I assume this would mean that in the event the front headlights fail that the fogs would kick in? Anyone with halogen lights and vagcom care to remove the plugs (so you don't have to remove the whole bulb) and check?
BTW interesting that some of the entries in the 607 version of VAGCOM are different/missing in the 704 version...
Funny - VAGCOM available for wine
MY07 Reflex Silver GTI | DSG | Bi-Xenons | Leather | Park Sensors
Bluefin | HPA SHS | Whiteline ALK | Neuspeed TAI | H&R 22mm RSB | Forge Catch Can | Seat drawers | Parrot CK3000 BT & QuickConnect harness VCDS MicroCAN | Mainline 156.9kW 329.9Nm atw
funny is offline   Reply With Quote
Old 09-06-2007, 03:01 PM   #46
vdubbaby
Fast is the only way!!
vdubbaby's Avatar
Drives: 2007 United Grey MKV
I have a vagcom and I was wondering if anyone knows that if you periodically ran the basic settings on the throttle body or calibrate the DSG will it improve the performance(i.e. throttle response)? Or would this F up something??
2007 UG GTI
vdubbaby is offline   Reply With Quote
Old 09-17-2007, 04:12 PM   #47
TEABAG
GTI Bunny hopper
TEABAG's Avatar
Drives: 2007 GTI MKV - CW 2.0T
Anybody in around norwood, MA who has the Vag-Com, I'm whiling to pay to get the DLR' shut off and the Windows through car key!:tongue:
GTI stands for Grand Touring Injected
VAG-COM-DRLs Off - Seatbealt chime - Conv windows UP/Down- Euro switch..6000K GE Xenons..Parrot Bluetooth -more to come!!!:eek:
TEABAG is offline   Reply With Quote
Old 09-18-2007, 11:02 AM   #48
CoolBreeze
Autocross Newbie
Drives: 2006 Jetta 2.0T
for the window roll down feature... can you make it only do the two front windows on a sedan? or is it all or nothing?
CoolBreeze is offline   Reply With Quote
Old 09-28-2007, 01:23 AM   #49
Wongster
Wongster's Avatar
Drives: Black Magic MKV
Other VAG tools
Anyone know or tried this tool??
Any comments?
It's much cheaper than the VAG COM...goes for 164$
http://www.autodash.org/index.php?ac...&cat=13&prod=1
Thanks
Wongster is offline   Reply With Quote
Old 09-28-2007, 12:15 PM   #50
dpham00
Modérateur Emeritus
dpham00's Avatar
Drives: 00 Passat 2.0T;07 GTI 2.0T FSI
Any comments?
Thanks
that tool/software could potentially cause damage to your car as you can read/write to the eeprom.
dpham00 is offline   Reply With Quote
Old 10-06-2007, 03:02 PM   #51
Flying_Finn
Flying_Finn's Avatar
Drives: '06 GTI MkV, DSG pk2
No Response from Controller
I just borrowed my buddies Hex-Com, installed the software on my laptop and tried hooking up to my car. The only controller screen that works is the transmission screen, all other screens return a "no response from controller" message. I cant figure out what is going on. The setup looks to be good except it says that the CAM is not active, but the damn thing just wont connect except to the transmission setup.
Any ideas what to do?
-finn
Flying_Finn is offline   Reply With Quote
Old 10-06-2007, 06:46 PM   #52
SoNgMaN
I Void Warranties
SoNgMaN's Avatar
Drives: 2010 4dr UG TDI HL
-finn
you need a CAN BUS cable. i believe the only ones that will work are Hex+CAN and Micro-CAN
SIGN MY SEARCH BUTTON PETITION - Hex-CAN usb Vagcom in the GTA i pwns all .::. KM Count: 140041
Originally Posted by SloppySRT View Post
give me a f!@#ing break, I've seen bigger tits than that in the kiddie porn I watch
187 WHP / 201 FT/LBS - bone stock - I have all this junk below now maybe i'm faster
::APR Stage2::Eurosport 3" DP::GT conversion::BSH DV::BSH stg2 PCV Fix::FK Silverline +X coils::Neuspeed P-Flow::30% tint::Forge FTB+STS short shift kit::Newsouth Boost Guage::BSH Dogbone Mount::textured mirror caps::smoked side markers::smoked mirror signals::sharan rep::Hoen Xenon Match Titanium::
SoNgMaN is offline   Reply With Quote
Old 10-06-2007, 10:39 PM   #53
Flying_Finn
That sucks. So the MkV GTI is a CAM only car?
Back to square one.. anyone in Southern Connecticut willing to share their VAG-COM cable?
-Finn
Old 01-02-2008, 06:31 PM   #54
Dr. Burgle
Rally Car Newbie
Dr. Burgle's Avatar
Drives: 2008 GTI MKV
My buddy has a VAG and he turned off my DLR's for me. We tried to set the window roll up my keyfob but couldn't find it in the long code helper.
Do you actualy have to do long code or is there a place in the helper to turn it on easier?
Dr. Burgle is offline   Reply With Quote
Old 01-02-2008, 07:15 PM   #55
CrzySpoolinIndian
What can brown do for you
CrzySpoolinIndian's Avatar
Drives: 2006 VW GTI
I believe this information is in the vag com guide that is in this thread, at least its what i used to do this on my car. Here is the info on page 7:
"-To enable the windows to be controlled by the remote (sunroof will only close), adjust
your bytes 6, 7, and 8 accordingly. Bytes 6, 7, and 8 shown below have been adjusted for
remote operation of the windows"
You basically click on the right byte in section 3 and make sure your check marks in the bits match pics....0C, 3E and 29 look like the ones you are after, remembering that the first byte is 0 and not 1.
08 Mustang GT Premium - MAC axleback, c&l intake + 87oct. tune
2006 TR GTI - Sold
CrzySpoolinIndian is offline   Reply With Quote
Old 01-05-2008, 12:01 PM   #56
ard
FIA World Rally Car Champion
ard's Avatar
Drives: '06 GTI, 6MT
i rear ended someone a while back and ever since i had the repair work done, the hood open indicator in the MFD is constantly going off. the body shop is willing to replace the latch but i would prefer to not have my oettinger bumper removed and reinstalled. does anyone know or would anyone be willing to check if it is possible to disable the hood open indicator in the MFD via VAGCOM?
Andy
APR Stage 2+ | APR RSC TBE | Neuspeed P-Flo | APR HPFP | Oettinger Kit
Eibach Pro-Kit | Koni Sports | H&R 24mm RSB | Neuspeed Endlinks | VF Mounts
42DD Catch Can | 42DD Shift Bushings | Neuspeed FMIC | NS TB Pipe | Rev D DV
Neuspeed SS Lines | EBC Redstuff | Newsouth Triple | Stinger SPV44 | 15% Tint
Alpine CDA-9887 | RF T400-4 | RF T500-1bd | Focal 165 K2P | JL 10w6v2 SB
ard is offline   Reply With Quote
Old 02-08-2008, 03:31 PM   #57
GT_GREG
zee germans are coming
GT_GREG's Avatar
Drives: 08 UG rabbit
Send a message via MSN to GT_GREG
hey guys.
im wondering if its possible for the vag tuner to turn off my drl's and turn on my parking lights when the car is moving with the headlights turned off?
currently my my headlights come on no matter waht as soon as the ebrake is disengaged.
and my parking lights(peanut bulbs in the highbeams) only turn on when the headlights are on.
can i program that differently?
GT_GREG is offline   Reply With Quote
Old 02-09-2008, 10:28 PM   #58
Rabbid0281
Oval Newbie
Rabbid0281's Avatar
Drives: Amelie
Rear doors throwing codes
So i followed everything for the remote windows, and my rear doors are throwing codes: Door Control Modules, No Signal/Communication. I cant find any other codes or things unchecked that might cause this to happen. Other than that, i have no way of knowing if the coding worked because nothing happens to the windows. Any help?
Rabbid0281 is offline   Reply With Quote
Old 02-10-2008, 05:22 PM   #59
Rabbid0281
Oval Newbie
Rabbid0281's Avatar
Drives: Amelie
nvmd, i mustve messed with something outside of the module. reapplied my base codes and then tried again, and now it works..sigh!
Old 02-10-2008, 06:33 PM   #60
fudsey
fudsey's Avatar
Drives: 2015 TR GTI SE w/lighting
Originally Posted by GT_GREG View Post
hey guys.
You need a euro switch to turn on parking lights without headlights. Mine worked fine without needing vag-com but my DRL were not enabled.
r
fudsey is offline   Reply With Quote
Old 02-11-2008, 02:22 PM   #61
GT_GREG
GT_GREG's Avatar
Thanks for the info! ill have to look into that further!
Greg
Old 02-11-2008, 03:22 PM   #62
dpham00
Modérateur Emeritus
dpham00's Avatar
hey guys.
you'd need a euroswitch and then disable drl's via the vag-com to run with just parking lights.
Old 02-18-2008, 05:49 PM   #63
Drone
Watching U
Drone's Avatar
Drives: 06 Rabbit
Send a message via AIM to Drone
Whats “flash to pass” sounds lucrative. Sorry im a vag noob. And great job with the list. Gonna get vag today at manic mondays!
Rolie
For Sale!
Drone is offline   Reply With Quote
Old 02-23-2008, 09:53 PM   #64
geeteeeye
Drives: tornado red gti
hey can anyone confirm that setting the fog lights as drl's will give them 100% current? thanks in advance!!
geeteeeye is offline   Reply With Quote
Old 03-27-2008, 01:59 PM   #65
MkVBlkMgc
Wir wollen lebensraum!
MkVBlkMgc's Avatar
Drives: '08 GTI 2Dr. DSG Blk Magic
A BIG to dpham00 for your vag-com doc!
I got my vag-com cable yesterday and couldn't wait to try it out. The documentation you put together made making changes to the programming a joy. I killed the DRLs, set the windows to open/close from the remote, told the car it was in Europe (it seems happier now), enabled leaving home, and more.
Vag-com rules and so do you, dpham00! Thanks again.
MkVBlkMgc is offline   Reply With Quote
Old 03-30-2008, 06:21 AM   #66
APXD 30
APXD 30's Avatar
Drives: 987S, 955/2,Maz GAC, VW, Saab
Ditto from PA! Nice work on the PDF. I got mine to work easily this weekend......now on to the Audi threads to figure out the A4.
Quick question, Is is possible to set the MFD to display speed like in a P-car?
JPD
'06 Boxster S (Stuttgart 5.12.06)
'08 Cayenne (Leipzig 6.18.08)
'10 Jetta
'07 9-3 SportCombi
'03 MazdaSpeed Grand Am Cup (track car)
APXD 30 is offline   Reply With Quote
Similar Threads
Golf-V Aftermarket Suspension Guide Gulfer Wheels / Tires / Suspension / Brakes sponsored by The Tire Rack 378 07-03-2017 04:09 PM
VAG on Canadian GTI? LiquidG Canada 7 05-25-2008 03:03 PM
where to buy and which vag com bis DIY + Maintenance + Tips/Tricks 21 05-29-2007 01:11 AM
FS: Elder Scrolls Oblivion Official Game Guide... Plyngntrffc Classifieds - Buy, Sell and Trade 2 09-23-2006 07:43 PM
VAG COM VDubbers Engine / Drivetrain / Exhaust 4 06-22-2006 04:55 PM
