Old 09-17-2006, 03:35 PM   #45
Mary and Phil
Mary and Phil's Avatar
Drives: 06 GTI MkV (Black Magic)
Originally Posted by Gulfer View Post
Single-side parking light
When parking on a very dark street (for example - no street lightings), to prevent some one stupid hitting your car by accident, you can switch on one single side parking light. The single side paring light only lights on one side (either left or right) of front (small light only) and rear small light, the number plate light is not on, to use as less power as possible.
To switch on the "single side parking light": Turn on either left or right indicator, then switch off the engine and lock the car. Once you locked the car, the direction indicator will no longer be flashing, and the "single side parking light" switched on instead.
They use it more often in Germany....
will the usa ones do this? i tried without locking and nothing happens.
i'll recheck it. ^^
Mary and Phil is offline   Reply With Quote
Old 09-17-2006, 05:29 PM   #46
NoRegrets78
OG
NoRegrets78's Avatar
Drives: 2016 Triumph Street Triple R
Send a message via AIM to NoRegrets78
i'll recheck it. ^^
That's also a Euro option only. VAG can fix this though.
Current: 2016 Triumph Street Triple R, 2014 Ford Fusion Titanium
Previous: 2006 VW GTI MKV APR Stage 2+, 2012 VW GTI MK6 APR Stage 2+
Coming: 2017 VW Golf Wolfsburg
NoRegrets78 is offline   Reply With Quote
Old 09-17-2006, 07:44 PM   #47
Mary and Phil
i'll see if my dealer can do that and the radio info thing when i get my radio flashed/replaced to fix the soft clipping.
Old 09-17-2006, 09:40 PM   #48
R-Bisch
L-VILE
R-Bisch's Avatar
Drives: 2006 GTI MKV DSG BLACK
Um... i think the whole auto closing sunroof thing is crap. just sayin. im pretty sure my dealer woulda mentioned that... he went throught everything with me when i bought my car. all the other stuff i knew exept the auto close and windows. just saying.....
GTi
R-Bisch is offline   Reply With Quote
Old 09-25-2006, 07:22 PM   #49
Zach L
VR junkie
Zach L's Avatar
Drives: Everything VW
Stop.. No go...
Pressing the brake (sufficient to light the brake lights) at the same time as the accelerator causes the ECU to ignore the accelerator input. This demonstrates the Drive by Wire system
I'm guessing this is a DSG-only characteristic. I heel-toe quite a bit w/ my 6-speed. Even with the brake pedal fully depressed, I still have full function of engine speed through the accelerator pedal.
European Auto Gruppe aka EAG - Houston-based Euro club going on 11 years
Zach L is offline   Reply With Quote
Old 11-19-2006, 06:33 PM   #50
Lima
Vorsprung durch technik
Lima's Avatar
Drives: Old and new skool
If you push ECON + rights button near Recirculated air. You will show into each screen in the climatronic several interesting values. If you go to channel 19 you will show in the right screen the speed, rpm, motor temp. The are others interesting channels but by the moment there is no info. To go to another channel just move the left temp selector to move to another subchannel just move the right temp selector.
Any reference to what the other values indicate?
MY80 GTI | MY07 GTI 3dr | MY10 S3 3dr
Lima is offline   Reply With Quote
Old 11-19-2006, 07:56 PM   #51
Fuzzbear
Fat bastard
Fuzzbear's Avatar
Drives: 2007 BMP PKG2 DSG GTI
Send a message via AIM to Fuzzbear Send a message via MSN to Fuzzbear Send a message via Yahoo to Fuzzbear
Dunno, when I was trying to see if my 07 DSG had launch control... it was definitely NOT ignoring the accelerator input when I had the brake pressed.
BMH-0666
Fuzzbear is offline   Reply With Quote
Old 11-20-2006, 12:21 AM   #52
Kirium
Formula 5000 Driver
Drives: 2006 VW Golf GTI
Alot of them (if not all), are in that attached document in the 1st post of the thread. Very little useful stuff in there tho...
2006 Golf GTI (Candy White|Manual|Bi-xenons|Sunroof|Interlagos Cloth)
Kirium is offline   Reply With Quote
Old 11-20-2006, 01:01 PM   #53
thomaschh
thomaschh's Avatar
Drives: Mk5 GTI
If you turn the sunroof dial about an 1/8th turn past fully open the sunroof slides all the way back into the roof.
There's no marking on the dial for this and I'm not sure why...
=tom
thomaschh is offline   Reply With Quote
Old 11-21-2006, 03:04 AM   #54
Jax$MkV
GolfMKV Veteran
Jax$MkV's Avatar
Drives: '07 GTI MkV
sweeeeet info
Jax$MkV is offline   Reply With Quote
Old 11-21-2006, 05:01 AM   #55
dlroto
Drives: waiting
Some really great info here, Thanx
dlroto is offline   Reply With Quote
Old 01-22-2007, 12:00 PM   #56
BetaOp9
BetaOp9's Avatar
Drives: 2006 VW GTi MkV /w DSG
Zone Climate Control Synchronization
if you hold down the AUTO button for three seconds, it will synchronize the temperature setting on both sides of the car to match that of the drivers side. When ever the driver changes his temp setting it will also change it on the passenger side, until a passenger changes their side.
Or just turn off dual and it will change both to diver side control...
BetaOp9 is offline   Reply With Quote
Old 01-22-2007, 12:14 PM   #57
BetaOp9
BetaOp9's Avatar
Originally Posted by SSS_Hoon View Post
yes it is, you have to have your wipers on the auto rain detect and it will close?
SSS_Hoon
We don't have an auto setting in the US. Nor do we have rain sensors. Stop trying to fuck up our cars. :)
Old 01-25-2007, 07:00 AM   #58
malkatraz
Touring Car Newbie
malkatraz's Avatar
Drives: mkv gti
Rain sensors are great though - you're missing out there.
I have DSG , sunroof, and bi-xenon.
Can confirm the window trick works a charm here in oz. I use it daily. Only wish I could start the GTI using the remote.
Also can confirm the sunroof sliding all the way back and the headlights (washers / rate depending on speed / reverse).
Have to add I like how the stereo changes volume depending how fast you're going. Useful and stock.
malkatraz is offline   Reply With Quote
Old 01-25-2007, 10:44 AM   #59
stangg172006
____ like a Rabbit.
stangg172006's Avatar
Drives: '08 Rabbit S
u have bi-xenon stock? are you sure? the only bi-xenon vw ive seen are the Touareg and the Phaeton...
stangg172006 is offline   Reply With Quote
Old 01-25-2007, 11:28 AM   #60
BetaOp9
BetaOp9's Avatar
We in the US have those items, most need to be activated with VAGCOM, takes a few minutes. The only thing are the zenon fogs, which we can get the oem kit for but $$$. The radio has a setup section which has that feature too which is reachable without any special tools.
Old 01-25-2007, 02:28 PM   #61
vantage
FIA GT Newbie
Drives: BM MKV GTI - 6spd
huh? All GTI's comes with xenons stock.
vantage is offline   Reply With Quote
Old 01-25-2007, 09:33 PM   #62
GTI2007
Moderator
GTI2007's Avatar
Drives: '05 UG Golf 5 Plus
All North American GTI's come with xenons stock. The rest of the world has to pay to get xenons on their GTI.
GTI2007 is offline   Reply With Quote
Old 01-30-2007, 02:01 AM   #63
AlowisiousGTI
Touring Car Champion
Drives: 2006 United Gray GTI
Well.. Xenon's and Bi-Xenons are diff.. the Bi-Xenons work for both low beam and high beam.. regulare Xenon's (non Bi-Xenons) are only low beam. But yes, im pretty sure that all us models are Bi-Xenon.
AlowisiousGTI is offline   Reply With Quote
Old 01-30-2007, 12:10 PM   #64
NoRegrets78
OG
All US models are Bi-Xenon.
Anyone have a link to the Xenon Fogs?
Old 02-09-2007, 03:36 AM   #65
Athfar
Drives: 2006 Jetta
Originally Posted by marx92x View Post
I've noticed that when changing lanes, you don't have to press the turn signal stalk all the way down or up (where it clicks into place). If you just bump it, the turn signal will flash for about 3 seconds. Doing this prevents you from accidently leaving the blinker on while driving (which most people hate).
I guess the only reason to "click" the turn signal would be if you were stopped and turning.
Cars have been like this for years now. It did it in the MKIII My 95 chevy blazer did it.
The one thing about the new VWs is the blinker stays on for like a couple seconds after you hit the signal turn. Which I guess is neat but what if you make a oopsie?
Athfar is offline   Reply With Quote
Old 03-09-2007, 12:15 AM   #66
-mission-
Direkt Schalt Getriebe
-mission-'s Avatar
Drives: MY07 Golf GTI
This is just a re-hash of the codes in the other doc ... a little google translation could help, but still much is a mystery.
- M -
-mission- is offline   Reply With Quote
