Old 01-12-2019, 04:13 PM   #1
zokiopp
Drives: Golf MK5 1.9 TDI 77kw 2003
Mk5 2003, rear wiper problem and passenger airbag problem.
Hello everyone. I am a new user of the famous golf 5 and this is my first post already.
1. I recently bought a MK5 1.9 tdi and i noticed some strange rear wiper behaviour. When i turn the ignition ON, rear wiper starts turning without command from the stalk and stops after several swings. When i start the engine wiper does the same again. While i drive, i turn on rear wiper from the stalk and it starts rotating but when i turn off it doesnt stop, it continues for few swings too and stops in a random position different from the default one ( like in the middle). It really pisses me off.
2. I get airbag failure error on screen after my friend exited the car from the front passenger door. Nearby mechanic cleared the code and i have no problems untill someone sits and exits from the car. The error code was passenger side airbag problem. I heard that i need to check connections but i dont know where are they located exactly.
Also, the previous owner stated that he changed rear door locking mechanism and the central one probably.
I would appreciate some help about these problems. Thanks :)
zokiopp is offline   Reply With Quote
Old 01-13-2019, 11:40 AM   #2
zokiopp
Bump: When i cleared airbag fault code, it reappeared only after passenger door opening.
Old 01-13-2019, 12:24 PM   #3
GTI's
FIA GT Champion
Drives: 2008 GTI Z4Z4 P03 PIP
Find someone with Vcds and do an Auto Scan and post up results. You probably have a module issue for the wipers.
GTI's is offline   Reply With Quote
Old 01-13-2019, 01:10 PM   #4
zokiopp
Got 2 faults with same code.
01222 - Crash Sensor Side Airbag; Passenger Side (G180): Implausible Signal* and one more with same type but it says Short to plus or something similar instead implausable singal.
Where is that rear wiper module located?
Old 01-13-2019, 03:02 PM   #5
GTI's
FIA GT Champion
http://wiki.ross-tech.com/wiki/index...ausible_Signal
This is the drivers door or passenger door depending on LHD or RHD. Crash sensor will have yellow plugs. Is the wiring to the door jamb B pillar OK no broken wires?
The rear wiper is controlled through the J519 module, I have no idea if the scan tool you are using has the capability to communicate with it. Generic ODB2 scan tool will not. Need Vcds or equivalent.
Old 01-13-2019, 08:16 PM   #6
zokiopp
I think it might be the wiring to the airbag because right after i clear the faulty code, i wont get any untill i open passenger door. Im suspecting the wiring between the door and the car pillar.
As of the wiper, i am using vcds. how can i check the j519 module?
Also, got another problem today. Yellow oil warning light. I had my oil on almost minimum, pour some more unitll below maximum and warning light is still on. i disconnected the battery and after i still had the yellow oil warning light on. xd a sensor problem?
Old 01-13-2019, 09:32 PM   #7
GTI's
FIA GT Champion
Your just going to have to look at module 09 J519 and see if you find anything in your module. I looked at address 09 J519 part number 3C0 937 049 AJ and its label file 3C0-937-049-30-H.lbl and did not see anything to check there even though the wiring diagrams shows that some of its wiring goes to it. I did find that address 16 J527 steering wheel control module part number 1K0 953 549 BP and its label file 1K0-953-549-MY8.lbl does have a measuring block for rear wiper.
The oil level sensor might also be a wiring issue.
